Aug 28, 2010 at 11:53 PM Thread Starter Post #1 of 4
furyagain
I just ordered a T1 from one of the head-fier
and also a t50p
other then the D12
i also thinking of the PB1 +DB1
but i don't understand onething
to use balanced setting with PB1 and DB1
i have to recable the headphones???
is there a adapter for that ??
i have to recable it to XLR 4 pin ? then use adapter?
also if i don't recable the T1
can i use this setting with the T1??( enough power to drive the T1?
Thanks You so much
Aug 29, 2010 at 11:47 AM Post #2 of 4
Any can that you plan on using in balanced mode has to be re-cabled. If you already have a can that is balanced (XLR3 or 4-Pin) then you need an adapter cable from whatever you have to the Hirose plug used by iBasso.
May 24, 2011 at 10:51 PM Post #4 of 4
Do you need a Hirose connection between the DB1 and PB1?
Yes, iBasso sells one for $39.   Much easier than making up your own.
