Rocaerix
- Oct 13, 2004
OK I decided a few weeks ago I would make a MINT headphone amp. I finished (basically) last night but when I went to test there was a small problem. I had no right channel
After much worrying i got out my multimeter (sp?) today and took some measurements. I had no idea what I was doing so i didnt get very far using that method
. However I did manage (somehow) to work out that it was the input connectors fault (I was wrong).
So i connected some alligator clips from the male jack (output) and connected them directly to the input cables bypassing the input connector. I then moved it round on input wires from the left to right channel but they both came out of the left channel no matter wether it was going through left or right input wires. I think the problem MAY be some bridged pads... i'm not sure so I quickly took some pictures:
Amp chip
Left Buffer
Right Buffer
Input solder pads
Output solder pads
Like I said I quickly took the pictures
. This was also one of the first times I have soldered as you can see and I kept stuffing up the Right Buffer before getting thinner solder which explains the flux/scorchmarks near it.
What seems to be the reason for only having left channel?
I can also take more proper pictures if needed.
Thanks
Rocaerix
Amp chip
Left Buffer
Right Buffer
Input solder pads
Output solder pads
Thanks
Rocaerix
