Rocaerix
- Oct 13, 2004
Yeh thanks for that I just checked again and OL goes to the Ground and OG goes to the Left. Will go change now and see if it works.
Originally Posted by Earwax If I'm intrepeting those images correctly, you need to check the output jack wiring. It looks like at the board end, you used green for ground, yet on the jack itself, the green wire isn't connected to ground. (the ground lug is the one nearest the threaded part) But with the heatshrink, I can't see all that's going on at that jack. and the link is misspelled in your post, it should be output jack |
