A PREVIEW of S.M.S.L SH-9 THXAAA-888 headphone amplifier
Nov 23, 2020 at 1:47 AM Post #16 of 27
Mine arrived last Friday, 5 days wait. Nice pair with the SU9:
Nov 23, 2020 at 6:46 AM Post #17 of 27
ShenzhenAudio https://twitter.com/shenzhenaudio Stay updated on ShenzhenAudio at their sponsor profile on Head-Fi.
https://www.facebook.com/shenzhenaudio/ https://twitter.com/shenzhenaudio https://shenzhenaudio.com/
Dec 27, 2020 at 3:37 PM Post #20 of 27
Does it make sense to buy the more expensive SP-400 for the Focal Clear? Is the sound quality better compared to the Sh-9? I think the Clear dosn't need a lot of power so the SH-9 is good enough and the chance is big to hear no difference. Is that right?
Dec 27, 2020 at 3:50 PM Post #21 of 27
I think the biggest difference will be that the SP-400 is truly balanced and has a bigger power supply. I have no issues with the SH-9 but I will be picking up the SP-400 hopefully next month to test the two.
Mar 19, 2021 at 4:53 PM Post #24 of 27
I actually use the SH-9 and would like to know why it is so powerless? I use the Jubilee on 70/99 and a AKG - Headphone on 80 /99 on the highest stage. My Ifi Ican SE was much stronger than this amplifier and the Ican SE has 4 Watt. Does the SH-9 really has 6 Watt? I think it is very good but it hasn't got a lot of power. I think it could be not enough for high impendance - headphones :frowning2:.
Apr 21, 2021 at 3:21 PM Post #27 of 27
Question: Is there a sweet spot for the balance between max gain and minimum distortion? Is it fine to run the SH-9 at 99 on the volume level, or is there measurably less distortion at 90 or 80?
Why asking?
I received my SH-9 and am using unbalanced inputs, into a pair of HD600s. Gain setting is on high. The source is my preamp, which is the same preamp I use into my speaker system. Getting the volume level in the headphones that I want (with the preamp volume left where it was for a speaker listening session) requires running the amp volume at 99. I don't want to have to reset preamp volume levels very much when I switch between speakers and headphones - to avoid the risk of me (having cranked the preamp up for a headphone listening session) blasting too loud into the speaker system by mistake.
My concern is that I may be causing distortion by running AH-9 at 99. So is there significant less distortion if I were to run the SH-9 at volume 90 or 80 for example? Does anyone have insight into whether the distortion increases with volume level on the SH-9 as we approach max volume?
