Thanks for the feedback Bruce, I will ponder on the present pie rating I applied.
kind regards
expat.
Extra Note: My original plan was to get about ten reviews on the blog finished and then go back and revise the pie scorings and try to work out a standard scoring rating.
Your system is fine in my opinion. Well balanced and audio quality in the first place of the pie chart. It's fine. I bet other reviewers, more in the "gadget" side of things, will ponder other factors above sound and that would be fine in their context. But this being basically an audio review is done very well.
Thank you also for your feedback.
I try to keep the focus more on sound, and I also attempt to make it brief so that readers can digest it in one quick sitting.
I'm not for a second suggesting that I have it right or that there is one single correct way to do this, but I found on my blog that scoring systems made things more difficult over time. For example: do you score a cheap earphone like the VE Monk based on its price or its outright quality? If you then have something TOTL on the same blog (i.e. Noble K10 with its outstanding sound quality and build / design quality), how do you then score that so people know that relative to the VE Monk (and vice versa). If you scored the VE Monk outright then it might get only 2-3/5 compared to a TOTL offering that gets 4-5/5, but then that becomes misleading for someone who is coming from stock earbuds and will find a massive improvement with a high quality budget solution. If you scored the VE Monk relative to its price then it should get a 4-5/5 because it's so good and yet so cheap, but now it looks (at first glance) like it is as good as a Noble K10.
I let go of ratings for this reason - too hard to balance different value levels and too hard to adjust the scores as newer, better stuff is released. For example, once upon a time, the iPod Video was a top notch portable player worth a solid 4-5/5. These days it's probably a 3/5 relative to what's available.
Not sure the answer here. My response was to do away with ratings and just discuss each product on its own merits, but that lacks the at-a-glance ratings that some people love so it's not the perfect solution.
Oh no! what have i done!
Haha, i only meant to give my 2 cents, not ruin someones blog/approach to ratings!
Well... thing is lots of things in life are like this. Take for example films (i'm a bit of a movie buff). I can see examples of lots of films I quite enjoyed such as Thor or Antman, I think they did a
fantastic job with what they had to work with. If you're familiar with the comics and arc plot lines that preexist, most Marvel movies are book adaptations, they don't have an awful lot of room to move. So within their own unique confinements I factor that in when I rate them. In a sense I would give films 2 ratings;
1) How well did it set out to achieve it's own goal (individual rating)
2) Where does it fit overall in amongst all other films (global rating)
So for example, take Thor, I think it did great, possibly a 9/10 as a individual rating, imo it succeeded very well in what it had to work with. But globally I can't justify that rating, not when other excellent (more serious) movies exist with that same (or less) rating (such as Room, The Revenant), so globally I would give Thor something like 6.5-7/10 (ie its a good fun enjoyable film).
Even the Oscars work like this to a degree. There are examples of films out there that are truly fantastic, the acting is fine and top notch, but if the topic matter of the film is of such where there isn't a great deal of serious emotional content then the film won't even get a mentioning. The Oscars might as well just be a 'An Award For the Actor/Actress who 'breaks down' the Best'.
The little boy actor in the film Room is excellent, he never even got a nomination for best Actor, or Supporting Actor, perhaps because he doesn't 'break down', but nonethless much of the success of that movie has to do with his performance to which he is brilliant.
Ratings are difficult. I just watched a first episode of a tv show rated at 8.5/10 (imdb), suggests it's good huh, well it wasn't very. Compared with well established good tv shows such as Breaking Bad, Game of Thrones etc (that sit around the 9/10), then the more rubbishy/average tv shows are getting really close to excellent tv show ratings... it doesn't make much sense. There is a
large difference as to how good a tv show will be with a
small shift in overall rating. ½-1 point is a massive shift for tv shows, not so much with films. If a film is 8.5/10 it tends to be good and worth it, same if 9/10. If a tv show is 8.5/10 and another tv show 9.2/10 there can still be a
large difference between the two (one is worth the time investment, the other not).
Digital cameras can be a little like this too. Do you rate the image quality in comparison to the absolute best camera that ever exists? Or do you rate it in reference to it's price point?
Getting back to DAPs, I only meant to say Feature wise it was sparse in comparison to it's competitions, and even on it's own merit. It actually DOES have some Features that screened DAPs don't commonly have! I read how one guy uses his Shozy for Marathon training (long runs). He is able to activate shuffle on or off, navigate to different albums, all done blindly and without looking at the DAP. Not many screen DAPs are able to do this function, most rely on line of sight to make such adjustments, or at least a very good memory as to what sequential button pushes are required to get you where yer going. Suffice to say the Shozy can do a few things better than screened!
And then there is comparing it with other nonscreened/shuffle style DAPs, which again I feel it does very well in.
Compared with the Hippo Biscuit+ it trumps it, the Hippo can't skip an Album (no folder jumping), that alone is a massive strike against the Hippo and a huge + for the Shozy.
So it all depends on where yer coming from. I just wanted to give my 2 cents, I found a product that has a richer feature set and still satisfies in the sound department, also costs less, so I would personally want to highlight the difference in Features more between the two units. YMMV.
