I'm sensible to a marketing which is well done. You know, Bose-style "better products through research" or how was that exactly. Therefore, I would tend not to let those wonderful marketing essays about the super-duper technology used in building an extra-uber-super-duper product (which, by coincidence, is also super-extra-duper-etc-expensive!), without a proper reward.
What about establishing a Prize for the best "technobable"... a prize to be given annually.
For example, I'm ready to offer to the first winner a 1/4 headphone jack which I will convince, by hypnotic means, to transmit unaltered frequencies up to 1GHz - so that the future owner won't have to worry about any skin effect of non-cryogenic treated materials. His only concern would be to get a cable whose properties would be modified in a similar way - to fit The Jack. And that cable... well... that cable... let's say that it will be made available at a reasonable price ("reasonable" considering, of course, the high-quality hypnosis involved in the transformation process, and hypnosis isn't exactly cheap nowadays).
OK.
I will submit to your kind attention the impressive explanation of the electrical skin effect, to be found here: http://www.head-fi.org/forums/f133/s...bering-443671/
Can you find better? Not easy, but still possible. Do your best!
Happy hunting
OK.
Happy hunting
