kingandrew
- Aug 20, 2014
Send a PM to MalVeauX and he will give you a list of options.
http://www.head-fi.org/u/179563/malveaux
Will do, thanks!
Well I just bought a pair for £80 delivered from ama*on. King or not!
My first decent headphones were a set of Grado s60i and I really liked them but build quality was not so great. Lasted me a couple of years.
They did sound a bit 'close to the stage', if you will forgive my ignorance of the correct terminology, and I am hoping for a slight improvement with the A-T's.
Closed back will help when I'm in bed and not wanting to wake the wife!
AT's also have a very close soundsatge although it will not be as natural sounding as the SR60i since the M50 is a closed back design.
Well I made a mistake with the order, read a few more things on here and ended up buying a pair of AKG 702.
Next step an amp.
Would be interested to see how they've been treated SD. There are people on Head-Fi who've had there 840's for years. I still rate it as one of the best closed budget cans out there. Yes they're heavy - but I found them very comfortable. YMMV.
The 940 though (I owned it too) - even owners who've babied their gear have had failures. Good sounding (weird bass though) - but very poorly designed.
i babied them and it broke in less than 3 months. i hope local shure will fix it. if not, i'd probably really disappointed and pissed. 3 months and $380 unbelievable.
Was it the SRH840 or SRH940 which broke? If it was the SRH940 - I wouldn't be surprised at all.
At $380 it sounds more likely to be the SRH940.
Yep - he pm'd me. SRH940. I've advised him to search for some of the replacement headband mods.
