Yeah, but once you count the distance inside each component that eats up a lot of the length. Maybe I should look into buffered lines, thanks. |
Audio Alchemy was once the "champion" of the I2S digital connection and if they had their way would be the standard for all things digital.Having separate clock/data/control lines has a lot of merit in my personal opinion and any time you MUX a signal (multiplex) you are looking for trouble just by the addition of "more" to the path.The SPDIF connection in fact spawned a whole cottage industry of "reclockers" just to get the jitter added by the receiver and transmitter OUT of what never had it to begin with.
for some background intel on I2S :
Pinout-
http://db.audioasylum.com/cgi/m.mpl?...2s&r=&session=
actual circuits from Audio alchemy (print out and study)-
http://www.audioasylum.com/images/dtipro32.pdf
http://www.audioasylum.com/images/DDE3.pdf
USB also eliminates the MUX/DEMUX part of the digital audio interface but in a different way entirely
That is a very philosophical way to look at it. |
Born of practicality.Something that may whip ass when conbined with a certain other device may in fact flat out suck if mismatched in a systemic way.
Beginning at the "start" there is a set of
knowns which make the unknowns easier once understood.The "all in one box" CD player on many levels superior than the two-box solution but what you usually are stuck with is corners cut for cost savings.It is here that you need to decide if your requirements are better served by separate DAC/CD Transport or if modifying the internals more practical (such as replacing everything from the IV stage outwards to the RCA jacks).Once you get to the output stage this will then determing what is needed at the next stage.
Why have 20dB gain (X10 gain) if you are already pushing 5 volts output at the CDP or DAC output jacks while having an amp that attains
full volume with 1 volt ?!?!
Would it not make more sense to have an impedance converting stage here,if such is needed,rather than gain which adds noise by a factor of the gain and makes your volume control close to useless by having all the adjustment at the bottom end of the rotation where tracking sucks ?
that or the inclusion of inline attenuators ?
What about if your source is a phono stage,or tape deck,or radio tuner ?
In "the old days" everything had its own volume control PLUS input attenuaors at the point before the input selector PLUS and overall volume control PLUS interchannel balance control PLUS many times a power amp "sensitivity" control (no more than another volume control) and this all because they could no foresee what additonal hifi componantry would be used in what combination or what the levels would be.
so the control preamp would almost every time have excessive gain "just in case" with many points to toss off the excess.
good practice is you do most of your attenuation at the front end amd least amount at the top end (at the speaker or headphonbe amp) for best S/N ratio and sensitivity comination.
all DIY means you can select exactly what you need thus eliminating the need to throw gain away.
Do a search here in DIY on "interconnections" or similiar items or better yet go stright to Jensen Transformers read everything in the FAQ section and then bounce over to the Rane Library for extensive info in level and impedance matchups.
For me personally i like to see four total gain stages from source to output transducer.
1-Phono stage/DAC output stage/tape head preamp/microphone preamp/tuner output stage (whatever the source is)
2-Preamplifier/Control Stage (in reality a "post" amplifer since the "pre" ceeding stage is in reality the "pre" amplifying stage with every single gain stage being an "amplifier" in reality) which serves dual duty as the entire gain stage section for and headphones.It may require the addition of a follower or matching stage but not another gain stage
3-Power Amplifier "driver" stage with "passive" gain being a real option here if the requirements not exeeding +6dB.A "true" integrated amp is really a three stage amp though these days the amount of gain available from digital usually means a two stage amp has a simple input selector/volume control added and then "called" an integrated
4-Power amplifier "output" stage
Toss in maybe an MC cartridge and you get an additional stage .
at each point all you want is enough gain to drive the next stage to full volume with enough overhead for peaks while not imposing and undue strain on the previous stage in its ability to drive it PLUS drive the next stage.sounds simple but not so very
