money4me247
- Jan 27, 2013
lol fun thread
No it happens in all sections. I wouldn't need my ears to be able to tell you that the portable player in the link below, would be better than an ipod for example. Simply because i know that the components inside the device will be of higher quality not forgetting the 24 bit dac inside it:
http://www.amazon.co.uk/Astell-Kern-Portable-Fidelity-System/dp/B00GXJU5QQ/ref=sr_1_3?s=electronics&ie=UTF8&qid=1442444483&sr=1-3&keywords=astell+%26+kern
I've been listening with my ears to a multi thousand dollar system for years now... quite like the one in the second video above, and all this talk of "no difference" is (from my point of view) making them sound very silly. It begs the question - how many of these people that make such claims have actually heard a multi thousand dollar system?!...
I've long held beliefs that are stated in this article (e.g. inconsequential effects of interconnects) however their statements about amplifiers is patently untrue. How can I trust the rest of their points when the statement "all amplifiers sound the same" is so clearly false?
That's because the Sound Science section of this website is full of people who are fixated on falsifying the truth. When one loses an argument, 2 or 3 others jump to their defence with even more BS...You will come to realise this as you read there posts.
If there was no difference in higher audio equipment compared to cheaper equipment, then these guys ( in the video's below) must be crazy. They sound pretty sane to me:
You'll see them try to argue why the system's in the videos above are not any better than an apple ipod next hahahahaa
you give us a lesson and end it with the lamest straw man argument about an ipod. great job showing your own integrity here mate.
and you sure made my point about caricatures.
When I first decided to get a "grown-up" setup, I went ahead and believed reviews and ended up with an HD800 + V200 + Bifrost setup, which is a multi-thousand dollar system. Then I found SS and started doing my own learning on the stuff,
. I sometimes think about giving up the HD800 too, but they're just too comfortable.
Anyone else cringe when those kids where sitting next to the turntable changing discs and putting on the record clamp?
Then they dance around the room. ..........
GIMME A FRIGGIN BREAK!
Reality is that if you are careful and not working in a mature technology it is possible to get better performance for more money to a point
My points proved then
Correction: Then you found SS and became convinced that they where right and you where wrong. Because they made themselves sound like experts when most of them aren't
cough "Castleofargh" cough. You let their ideas fool you...
Who would give up HD800's man...they are more than just headphones. Headphones like those and my old Denons can invoke the sense's...
Your point was that:
"The quality of components inside an amp dictate the quality of the sound. All electrical engineers know this (my father is one). An amp with dirt cheap components and transistors will convey the signal and that's that. However, one made of top components and transistors with the finest capacitors required to convey the signal, will ultimately output a better, more preserved, less degraded signal."
Was completely disproven, and let me be more clear for your benefit.
(1) Once the quality of components inside an amp reach a certain generally achievable level of quality, further improvements in their quality cannot improve the quality of the sound. For example, I can build an amp out of 1%-5% metal film resistors (the current commodity mainstream) and further improvements in component quality (to say 0.1% metal foil resistors) will have no audible benefits. The higher quality components are for precision instrumentation, not consumer audio gear. Using them is just like putting aviation gas into a car that is designed for low lead, low octane gas.
(2) It is true that an amp that is built with commodity components will convey the signal but not only is that that, it is all that is needed for the best possible sound quality.
The general quality of commodity components has improved considerably since the early days of audio. Back in the 1950s audio gear sold by Marantz and McIntosh that still commands fantastic prices contained commodity 10-20% tolerance carbon composition resistors. Today the standard dirt-cheap SMT resistor is a 1%-5% metal film part which is a far, far better part and for most applications impossible to improve on for audio.
(3) There are other strong determiners of sound quality than parts quality, such as circuit design and configuration. There is a lot of overpriced high end audio gear that poorly designed and thus
betrays the quality of its parts.
(4) Improving the sound quality of an audio system by improving the electronics beyond commonly achieved standards is generally futile since the limits to audio system sound quality are generally related to acoustics and transducers.
You are essentially saying the same thing as me. But take an entire multi thousand dollar system, Mono blocks, exotic cable's blah blah blah...Cyrus cd player with 24 bit Wolfson dac inside...then use summit fi speakers or headphones...now take a Marantz cd6005 with a 6005 amp...would you honestly say there is little to no difference?....i mean come on.
You and me both know that's not true. Yet it's what you'll find plastered all over this website and sadly the internet. I only tried to make people aware of this by posting on this forum.
It really does make me sad to hear these "no difference" claims...
It is not uncommon for me to hear the disc spinning in between tracks through my speakers/headphones... ( from my 24 bit Wolfson dac Cyrus cd player). That's an indication of the importance of the quality of the internal components. (btw it's not a faulty amp, it's the actual disc i often hear)
God help me if I'm saying the same thing as:
""The quality of components inside an amp dictate the quality of the sound. All electrical engineers know this (my father is one). An amp with dirt cheap components and transistors will convey the signal and that's that. However, one made of top components and transistors with the finest capacitors required to convey the signal, will ultimately output a better, more preserved, less degraded signal."
Please explain how my statements are the same thing as what you say. They were designed to say something quite different, i.e., convey the true facts of the matter.
Then it appears that you change the subject, not once but twice. That is pretty much a concession on your part that in fact you have no relevant, on-topic way of of explaining your claim that our statements are "The same thing", isn't it?
If you hear the disc between the tracks (i.e., the CD player is not internally muting itself), Then the noise is by definition of the Redbook CD format no more than 93 dB down. Reproducing that accurately with modern commodity grade electronic components is simply not a problem. Therefore the additional, off-topic evidence that seems to be brought gratuitously to the discussion does not support your thesis.
You are good with your words. That in turn creates a superiority complex. I'm simplifying what your saying for less technically minded people...
I might not know everything in the world but i sure as hell know what i'm talking about here. You jumped in on this discussion at the right moment. That's because no one else could counter what i was saying because they don't understand it like you do. Why is the glass always half empty with guys on here...
Word for word what you have been posting in this thread confirms my point, your just over -complicating your words to make it sound like i'm wrong.
I'm just as clever as you...but i hide it well! and right now your probably trying to find some proof that i'm wrong...
No, you're completely changing what Arny is saying to fit your opinions. Opinions which you've consistently been unable to support with any factual data.
People aren't over complicating their responses to make it sound like you are wrong, people are posting accurate information proving you are wrong. Big difference.
