helloh3adfi
I like Ascension best with Dunu S&S tips on. Though Auroras are still more comfortable than Ascension on longer sessions.
Love the storytelling! Now let Ascension do some singing for you. Trust me, you'll be impressed.Here, we see a pair of baby Ascensions cuddled in their beautiful copper and silver nest. The pair are about to sing for the very first time.
It's very strange to me. First 30 seconds. It sounded like there was something wrong with the monitors. You can hear the sound changing with every song. I can now hear fingers sliding on the guitar strings 4 songs in. This is a new experience for me.Love the storytelling! Now let Ascension do some singing for you. Trust me, you'll be impressed.
Then, let these babies burn in for 50h+ and experience the bass getting even more lush and comforting.
Hey Man, I absolutely can't share your excitement for the IEMs; that's only your thing...Okay. It's 1 am and the wife is growling. Sadly I am returning the little birdies to their nest. I am posting too much as well. Time to go to sleep.
You need more volume than Neon Pro, not sensitive the same way. more like 30% vs 58% volume on my DAP.While I am asking questions of Ascension owners, how sensitive are they compared to the Neon Pro, do they need about the same volume setting, are they sensitive to hiss on conventional gear ?
About depth, I guess its fairly similar as NP. Maybe slightly less.
I dont get any hiss out of both BAL and SE from the Gryphon. I mainly use SE on my sets cause of this reason though. As for fit, since you usually use a large tip fit should be as good as NP imo. This are deep inserting, unlike the IE600 for instance. That is why fit can be tricky. If you normally use MS or S tips you might have trouble with the wide nozzle not allowing it to sit all the way in your earGosh that is a big difference in sensitivity which would be very nice if they are a bit less susceptible to hiss.
Ascension has a bit shorter nozzle than NP, but it's thicker, so I am willing to bet you shouldn't have any issues with its fit.Despite trying to talk myself out of the Ascension I am likely to order a set soon.
My final concern is fit since I have a couple of sets that I have struggled with recently. Those were both somewhat shallow fit and I needed to resort to the XL size Penon Liqueur tips to get a seal and firm hold in the wider outer part of my ear canal. For reference IE600 was one of those sets and for reference the XL Liqueurs work wonderfully.
The Neon Pro is an absolute perfect fit for me in term of size and insertion depth meaning I can get a good seal and firm hold with all manner of tips and I am not choosing for only functional reasons.
Looking at pictures of the Ascension they look very similar to the Neon Pro, is that he case. That is, is the insertion depth essentially the same as the Neon Pro and significantly deeper than the IE600 for those that have them as well ?
I read about the wider nozzle, pretty certain that won't be a problem as I use large size tips anyway even with the deeper insertion of the Neon Pro.
Many thanks
It needs/loves plenty of power and it is by far the hardest to drive out of all AüRs. No hiss on any of the sources I've tried.
