whirlwind
I just purchased one 2.5 balanced from amazon.
I can't wait to give it a listen.
For me, yes, the Moondrop Blessing 2 Dusk is a better all rounder. More natural tuning, less bass particularly mid-bass and more restrained pinna gain. The Timeless is more V-shaped. It does what it does very well though, and is sparkly without being fatiguing.I think think the big question is, do you guys have a better overall IEM?
Yes my Z1R but in the same price range as Timeless nothing comes to mind.I think think the big question is, do you guys have a better overall IEM?
Anybody paired the Timeless with a Chord Mojo?Also worth mentioninng that Apex Teton is high end amp with price of 5000$ and hd800 1500$ senheiser pre top headphones. Naturally that 200$ iems can't be compared, even mentioning at the same post are a little bit out of place.
I got them not very long time ago and can say that for my ears and from what i heard glowing reviews of timeless is less glowing than these iems actually are for their price. They are not end game for everyone and no one says that but for majority budget minded audiophiles they can be easily. Buying them is actually spending less because each $ you spent on them can be multiplied x2 or x3 for their actual sound. And with some other audiophile gear i bought actualy real value i got was like /2 /3 for their asking price. So one more new happy 7hz owner subjective thoughts. Now only left to find best source for them and ofcourse will try as many tips and cables to squeeze every bit of them.
Would like to know too.Anybody paired the Timeless with a Chord Mojo?
Oh yeah, everything in my signature. Timeless are at the bottom.I think think the big question is, do you guys have a better overall IEM?
Well, I have a Mojo with a Shure se846 usually plugged.Would like to know too.
While the timeless sound very nicely out off my desktop set up, I'm less convinced using my E1DA gen3 dongle. So I might pick up a used Mojo if synergy is great.
Sometimes they can be the best on a certain recording, but overall they are at the bottom. Timeless are a specialist variety for me.
Would the Fiio LC-RC do with Timeless?I concur, timeless is at the bottom of my stable but definitely a keeper. It’s wonderful for bad recordings as it is classical to jazz. It does have issues resolving in busy sections of tracks however…I’m waiting on my 8-core Graphene cable to arrive to see if this helps but generally in my experience a cable cannot fix a monitors inherit flaw. For example, the Isabellae single DD showed grain in busy sections of tracks and this never went away even paired with a $2500 cable. It smoothed out a little bit but was always present no matter what cable was used. So I wound up going back to the stock cable of Isa for the pure ergonomics.
I’ve journeyed long and far with cables and for me, I won’t go Uber expensive anymore. I will keep it under $500(honestly prob $300 unless I love the design, ergonomics etc) that is my limit as I’ve learned a lot from my cable rolling.
Edit: I will say at $200 I’ve found nothing to top timeless as it’s a bit unfair to compare them to kilobuck and up monitors.
