"Popping" can actually be an audible "pop" when some element of the driver gives way / gives out, it can be a wire, component, but usually for over driving the actual driven element of the speaker has an over excursion event where the membrane separates from it's flexible attachments, or the membrane simply tears away from itself. Another kind is where the coil overheats and separates.
Usually you don't hear anything from it after it pops, only silence, But, with a torn vibrating membrane it might not be a clean separation initially, a ittle tear that can over time cause a failure can occur.
But that Planar membrane is pretty darned tough, so if it didn't tear - you'd know it, the sound would change drastically, a buzz/vibration/distortion would be clearly audible.
I've never heard a Planar pop, or give way, but I have heard woofers and tweeters fail, and you'd know it right then - after the initial shock of the event fades. Like I said, I'd give it a few days away and then come back after your mind is clear.
It may take listening side by side with another 7HZ TImeless to convince you for sure yours is ok, the human mind is a strong believer in mistaken beliefs.
