Steve999
smooth, DARK
- Jul 15, 2002
Thanks. And thanks for the CD recommendations! I'm experimenting. Learning new things. That combined with my streak of silliness can lead to unpredictable results. But I'll get down to business soon enough.
I told you what to do to detect what I was talking about. Don't use VBR. Use CBR. Encode in Frauenhofer at 96 first so you can identify the trouble spots. Then encode in progressively higher rates and check the same spots in each one. At some point it will disappear. That is your line of transparency. You shouldn't be listening for reduced high end. That is a given at low bitrates. Listen for compression artifacting. Print this out if it will help you when you're trying it.
Ultimate Bobby Darrin https://amzn.to/2sJTrXE
Ray Charles Modern Sounds in Country & Western Music 1 & 2 https://amzn.to/2xXOqzT
Louis Prima Capitol Collectors Series https://amzn.to/2kWJjX8
Kay Starr Complete Lamplighter Sessions https://amzn.to/2JA1oVx
Johnny Ray The Very Best Of https://amzn.to/2y4jb5U[/SIZE]
Dinah Washington Essential https://amzn.to/2Jwj8kV
Every one of these is a 10
