kernel8888
- Jul 11, 2013
Crap I missed the memo on sending a message to all 3, mine are on their way to silver ears
Nope, just stock. Will try out other DAPs with Forte.@SilverEars Did you do any cable swapping with the fourtes?
Short impressions. I prefer the Tzar over the Forte. I do like BA bass when done in good quantity, in which Tzar achieves.
Forte sounds a bit veiled in comparison to Tzar. Tzar has the treble sparkle that is needed for the more forwarded detailing and resolvability.
Tzar is airy and has a rather large sound stage in comparison to the Forte.
Tzar is clear sounding and I really cannot pinpoint any mids unclaritywhich is important to me. The bass is a bit rounded in nature than more on the defined side, but good quantity and provides slam for those like to feel it.
Ample weight to the sounds if that is a concern for others.
I think it's quite balanced. What I mean by balanced, there doesn't seem to be noticible frequency discontinuity or sounding uneven, mids have the appropriate level of presence, and bass does not overwhelm the mids clarity.
Could be considered warm for those that isn't into bass quantity, but I find it's necessary to bring naturalness, create ambiance, and bring weight to notes.
I can see why 1964 catagorizes Tzar as linear compared to the others like the Forte. I'd consider Tzar reference sounding, but not clinical.
Speaking of cable swapping I have the Leonidas arriving soon for my Fourté
The cable that comes with the Fourte sounds really good, what made you want to upgrade? Will it add a better sound signature?
Most reviews on the Leonidas say that it doesn’t change the sound signature but rather emphasis everything.
I needed a balanced cable also.
