Lateness
- Oct 25, 2012
Is there a similar test done on here with 128kbps vorbis or 160kbps MP3?
A Double Blind Test is calling for you - FooBar has a built-in ABX. A minimum of 15 trials is suggested.
Piece of cake Nick. I use JRiver. WASAPI event style. Yeah, 24 bit native sounds better than 256k AAC.
Don't be shocked.
Don't be shocked.
Also, try converting the 24 bit version to high bitrate MP3, Vorbis, or AAC yourself using a good encoder. It could easily be the case that the iTunes version has more "loudness war" dynamic compression and clipping, and sounds worse mainly because of that, rather than the format.
I have Sunken Condos ripped as ALAC if you need any samples of that to compare as well.
Did you RIP it from the 16 bit CD? I have the 24 bit files. I did convert them to 24 bit ALAC for library purposes in itunes.
The CD is very likely a different mastering than your 24 bit files.
Just the 16's here off of the CD.
"Traders Little Helper" I'll have to pull that down tonight looks very useful.
The master tapes were done in 24 bit. I'm sure the 16 bit CD also sounds nice. It's a good album too, if you are a Steely Dan fan.
