gregorio
- Feb 14, 2008
Bit depth? You guys use hybrid SACDs and feel the different when reading each layer? Yes! Different.
Yes, it often is different but that's not the question. The question is, why is it different? Is it different because SACD or other "hires" formats are better or is it different because they've deliberately used different masters for the different layers? The answer is the latter, when using the same master no one can tell the difference between SACD (or other hires formats) and CD.
This isn't necessarily true of the lossy formats like MP3 but even then, if using one of the better versions it's virtually impossible to tell the difference.
G
