24bit vs 16bit, the myth exploded!
Feb 3, 2017 at 9:38 AM Post #3,647 of 7,175
3. OK, this is way off topic but generally they tend not to "record lower". Location sound guys are usually taught to try and get a peak level of -6dBFS, they could/should easily go much lower still and not affect the noise floor. The mic-pres on industry standard location kit (Sound Devices) are very good but at the standard film reference level (-20dBFS = 0VU) there is no benefit in trying to peak at -6dBFS, -12dB would be better.
I checked with my friend who does location sound, and confirmed the -20dBFS reference, and he meters with PPMs (and true peak).
I know and have owned Sound Devices stuff.  Great stuff.  If they use one of the field recorders it's probably fine, but the stand alone mic pres can easily be miscalibrated relative to the system.  Only when all clipping points are aligned in the system do you get maximum DR.
Why would you want max peaks at -12dBFS?  Talking Maximum now, not typical.
Feb 3, 2017 at 9:48 AM Post #3,648 of 7,175
  I remember when CDs were introduced the slogan for the medium was perfect sound, forever perfect. Now, if that statement was true, then how can todays hi-res be more perfect? I know that I can't distinguish 16/44 from 24/96 so all of these bigger files seem to do nothing more than fill up library space. I remember when digital was just an idea and the idea was that 16/44 was all that was necessary to assure the best possible outcome.
You know what marketing is, right?  The terms "perfect" and "forever" are marketing terms.
16/44.1 was chosen because it formatted well within a frame of NTSC video, and video recorders were the affordable solution to recording all that digital audio data.  Soundstream was already doing 16/50.  Limits were in data recording an reproducing, and sampling frequencies were considered to be high enough to capture all the necessary audio, but also it wasn't really possible to go higher initially.  44.1, in particular, caused a problem: the anti-aliasing and reconstruction filters were complex (analog), and pretty radical beasts, hard to make well and cheap.  A lot of fingers were pointed at those filters, even spawning an "upgrade" industry.
Feb 3, 2017 at 9:59 AM Post #3,649 of 7,175
  Of course they were.  But we're talking digits here aren't we?  So, the digital realization of a ring modulator.
I was stating that for the historical record. Kind of like making a reference to vinyl.
Feb 3, 2017 at 10:10 AM Post #3,650 of 7,175
  And I'll pay for shipping on your 2600 plus $200.
Sorry, I'm keeping that for the historical record, along with my Moog Sonic 6. I should've kept a Mini-Moog .I have a Roland SH-32 Midi/Digital simulation of an analog synth, think it lacks a ring modulator.
Feb 3, 2017 at 12:16 PM Post #3,651 of 7,175
  This video will answer all your questions concerning audio from 16bit to 24bit audio...Lot of laughs starting at 20 minute mark.
This video is so comprehensive, and addresses so many of the points that get continually restated here, that we should make a sticky post at the top of the forum for it.
Feb 3, 2017 at 2:08 PM Post #3,653 of 7,175
I watched it from beginning to end - excellent presentation.
So my take, as I tried to present in the AptX thread (with little success) is that while I have no problem whatsoever understanding:
1. "garbage in, garbage out"
2. We can't hear above ~20K (and in my case, probably much less than that)
I was nevertheless very pleased to hear him state hi-res in, hi-res out:
(link goes directly to 29:10)
Which is why I am (still) aiming for gear capable of  ~24b96K playback.
And no, I doubt I could prove it makes a difference via A/B but when I see the "data" above 20KHz then I feel okay having spent a little more for so-called hi-res playback HW...
Feb 3, 2017 at 2:31 PM Post #3,654 of 7,175
What hi-res playback hardware would that be?
Feb 3, 2017 at 5:29 PM Post #3,657 of 7,175
Rats. It's late here... . So Reset.
The answer to your question is listed in my signature.
But given that 24b96K DACs are a dime a dozen and even my T5p.2's 5-50KHz specs will not pass muster I'm sure you've managed to make your point with the one question
Feb 3, 2017 at 6:34 PM Post #3,659 of 7,175
Personally I find it refreshing to see someone acknowledges that there is no real audible difference - but acknowledges that they can feel better listening to 24/96.  That's simply humanity at work. Everyone knows I try to be as objective as possible.  I know that aac256 is pretty much transparent - so I use it pretty much exclusively for portable use.  But if I'm home, I use FLAC, and I even sometimes upsample to DSD (even though I know from an audible point of view it isn't making things any better - actually could be worse).  But it lights the little blue light on my iDSD - and sometimes it just sounds better to me with the little light on.  Pure placebo - but if it makes me happy, and doesn't hurt anyone - then why not?
If only more people would do the proper research, and be open to the science, we could demystify it a lot.  Then the claims that one res is audibly better than the other would stop.  And we could be left with personal preference - and a lot less debates
As per usual though - the quality is in the mastering/recording.  I had a listen to some of Mark's catalogue.  They are indeed excellent quality.  My thanks to gzubeck for posting the video - more music for me to explore.  Fun!
Feb 3, 2017 at 7:04 PM Post #3,660 of 7,175
