lantian
- Dec 14, 2016
Judging by some of the comments you read, I think a lot of the audiophiles are already experimenting with this
In my opinion that is how hifi kicked of, but hey that's just me
We should include alcohol consumption in the next study
Yeah, for me, music always sounded way better when I'm happy.
When I try to remove all the biases I can though, I can't hear any difference. The more I think I hear something, the more I hear it. Then I swear I hear the opposite once I confirm that it actually wasn't what I was playing.
D:
Key to enjoying music: be happy!
I guess most will agree about this, but what if
"I'm only happy when it rains
I'm only happy when it's complicated"?
You guys have had a reality forum show going on, I missed the entertainment. Must be the audiophile grade of LSD that's been going around, makes one hear things.
So what kind of precision does one need when multiplying 2 different 16 bit numbers for sound effects like ring modulation? Certainly 16 bit precision in not adequate, unless one is willing to compromise by scaling down the two inputs prior to multiplication.
so what makes some recordings sound insanely smooth vs. recordings that make you want leave the room?
Whats the higher sampling rates for?
Doesn't a higher sampling rate improve anything?
Is it strictly poor equipment and increased loudness?
Originally Posted by pinnahertz /img/forum/go_quote.gif
[1] It's the "law of uncorrelated summing", you build level 3dB every time you double the channel count (assuming uncorrelated signals at the same level). It's why even analog mixers provide for lots of extra headroom at the mix bus, and a bus master.
[2] In all the forum battles I've read and been involved with here and elsewhere I've never actually seen a conversion take place in either direction.
[1] So what kind of precision does one need when multiplying 2 different 16 bit numbers for sound effects like ring modulation? Certainly 16 bit precision in not adequate, [2] unless one is willing to compromise by scaling down the two inputs prior to multiplication.
so what makes some recordings sound insanely smooth vs. recordings that make you want leave the room? Whats the higher sampling rates for? Doesn't a higher sampling rate improve anything? Is it strictly poor equipment and increased loudness?
Higher sampling rates are simply producing more life like resolution of your music. Human ear is perfectly capable of hearing the difference between higher sample rates. The so called auditory resolution of human hearing is about 5-7us, a 44.1khz audio has each slice of 20us, 96khz has something like 10us, and only 192khz can offer time resolution of 5us. That would seem perfectly smooth to our auditory systems/brain. Go ahead and correct me If I am wrong on this.
have a look 2 pages back of the images I posted.... in 24 bit resolution it's impossible for any human to hear the difference between 192khz, 96khz, and 48khz, as the files are IDENTICAL below 23khz
[1] so what makes some recordings sound insanely smooth vs. recordings that make you want leave the room? [2] Whats the higher sampling rates for? [3] Doesn't a higher sampling rate improve anything? [4] Is it strictly poor equipment and increased loudness?
