Soundsgoodtome
Ok, that makes sense. Well I'm certainly looking forward to my results. Maybe if the outcome isn't what i think it is I'll be able to free some space on my portable for lossy.
^I disagree. You make it sound like it should be a glaring difference in sq, I doubt that. You may even need to have several loops of playing the different samples to differentiate the two files being compared.
For the majority of my listening its about enjoyment, critical listens are for testing and usually only when I get new gear or hear something amiss. Not to say high fidelity isn't appreciated (why would head-fi exist). But I haven't ditched Spotify for Tidal nor do i plan to but i can definitely hear the difference there. Could be a matter of Spotify player being a factor. It'll be interesting to test cd ripped ogg vorbis and different since both files are going to be Foobar. I'll entertain having lossy but since I've got massive terabytes for storage, why not keep source files in the purest of forms?
You claim that you can definitely hear a difference between what I assume is Spotify's 320kbps Vorbis and Tidal's FLAC. The word "definitely", to me, seems like it should be every time and nothing less. This is an easy test to ABX in Foobar. Go for it. Let's see some definitive results.
http://www.head-fi.org/t/655879/setting-up-an-abx-test-simple-guide-to-ripping-tagging-transcoding#post_9268096Take a CD, rip. Use that rip to make a LAME 320 MP3. Do a blind level matched test. Get back to us. (Don't assume two different sources for the same song are the same mastering. They probably aren't.)
So the other gent here that got 9/10 and 8/10 in his abx test, what do you think of that? Think he's lying? Maybe there was some other factor perhaps, say unknown original source FLACs not from his own cd collection.
There's more to these tests than the final sample ratio, but getting that all worked out on a forum is a messy business that usually pisses someone off ^_^
The thing is, the differences aren't night-and-day obvious. You have to listen carefully and look for certain things.
Ok, I will, as soon as I have the free time this week to do it.
Regardless of the outcome, I'm not about to change my collection to aac files. Even if I fail miserably, I'm sticking with lossless. I have the storage space, so there's really no reason for me to switch. I'm quite comfortable with my archival process.
And it will not stop me from picking up 24bit, high resolution copies of my favorite albums as time goes by.
I don't agree with the 100%. No one's perfect, and even experts can make a mistake. 9/10 (or equivalent) is a reasonable compromise with a margin for error. Doing anything 100% perfectly all the time is impossible for us as humans.
The thing is, the differences aren't night-and-day obvious. You have to listen carefully and look for certain things. For me, I can hear the differences in cymbal crashes and delay effects the most. It helps for the recording to have nice dynamic range too...I can't tell the differences between lossy/lossless with "loud" recordings. There's just not enough space to hear the tiny details.
