24bit vs 16bit, the myth exploded!
Mar 1, 2015 at 9:40 AM Post #2,761 of 7,175
Mar 1, 2015 at 2:56 PM Post #2,763 of 7,175
320kbps ogg Vorbis (better than mp3 coding I'm told) vs cd flac. People make the claim sure but I can honestly say I heard it on my HE560 rig, the latter is better and it's more noticeable in the treble.
How does one prove it with definitive proof over a forum? Just because people say it without proof doesn't automatically mean they're lying, you are entitled to your opinion of course and ymmv yada yada.
Can you prove it? A lot of people make this claim but most can't.
-He didn't specify the bit rate of the mp3.
Heck, even I can tell the difference between flac and a 64kbps mp3 of the same recording... :-)
Mar 1, 2015 at 3:04 PM Post #2,764 of 7,175
How does one prove it with definitive proof over a forum? Just because people say it without proof doesn't automatically mean their lying, you are entitled to your opinion of course and ymmv yada yada.
Download foobar2000 if you haven't yet, find and download the ABX Comparator plugin, do 10 or ideally 20 trials comparing the OGG to FLAC, and post your results. For lack of a more controlled test, I'll take your word for it if you pass this with confidence.
Mar 1, 2015 at 3:39 PM Post #2,767 of 7,175
  What percentage do you all consider to be passing, or sufficient? Do you have to get it right 100% of the time? Or just a majority?
It all depends on what you want your false positive rate to be. If you are fine with 5% of tests* yielding a false positive, then 9/10 is considered enough. Here are the necessary correct trials (for 5% false-positive rate) shamelessly stolen from Wikipedia:
Number of trials​
10​
11​
12​
13​
14​
15​
16​
17​
18​
19​
20​
21​
22​
23​
24​
25​
Minimum number correct991010111212131314151516161718
*Note that a "test" means the entire set of trials you have decided to do beforehand
Mar 1, 2015 at 3:56 PM Post #2,769 of 7,175
Number of trials​
10​
11​
12​
13​
14​
15​
16​
17​
18​
19​
20​
21​
22​
23​
24​
25​
I didn't particularly care about this before, but I think I'm going to do this again with more variety. I did it once before, and I ran 2 trials of 10. I scored a 9 and an 8, but I didn't save the logs. I assumed that meant I passed. This was between a FLAC and a 256 AAC.
I'll do some tests with 16 and 24 bit too, because why not. I've got free time this week.
Mar 1, 2015 at 4:03 PM Post #2,770 of 7,175
The 9 is a pass; the 8 isn't (at the 5% level), but there's a lot more to doing a correct ABX test (level matching, etc) that can be automated by software. What are you going to do these tests in?
Mar 1, 2015 at 7:24 PM Post #2,775 of 7,175
Complexity of the music isn't the issue. There are just certain kinds of sounds that are more prone to artifact. Transparency is the lack of momentary artifacts. It isn't an overall sound quality. It's that the higher the rate, the fewer artifacts there are, until the artifacts disappear entirely.
