@limp: Thanks for running that. I really appreciate it. Real runs and results I'm a fan of - whatever the outcome or shortcomings. Inuendo about my Starfleet cadet history .... not so much.
To be clear for everyone, referenced by you and several other posts, I am not hearing any noise floor. There was speculation about cranking the volume to the level where I could hear noise. I have not done that, and no matter what volume I tried I did not hear noise or any other non-music artifact in any of the 12 clips I have, in either 16 or 24.
The way I got the result on the above Linn test192 was listening for a certain quality I heard on the 6th note played by the clarinet. It is difficult to describe, but it is a certain roughness on the front end of that held note, just the first little bit, in the 24b version. The 16b sounds a little thinner or purer. I'm not sure whether it is the reed or actually distortion within the instrument as that note is played louder. I also tried listening to the reed "shhh" on the first note, and the sounds of the key pads closing which I can hear quite easily in both the 16 and 24. Unfortunately I could not zone in on any difference and that probably accounts for about 10 trials.
Give it a try. Maybe you have better equipment.
So the question is am I guessing? Well I don't really know. I feel I can recognize that detail, but sometimes it is very hard to pick up. Then I start to hear it well, and I get a streak of successes, often with quick decisions. Then it eludes me for a bit. I saw one poster recommend taking a break every 5th trial. Good idea but I havnt had the time yet.
@RRod: Honestly I don't have a set criteria. I'm open for input. Many posters suggest at least 5% or better 1%. If I saw any run of >10 trials with 1% result I would call that absolutely not guessing. I did hit 5% a couple of times with lots of trials so I'm really on the fence. Note my better runs correspond to passages and pieces where I've heard something specific. I have other runs on different pieces that look very different, starting at 60% and heading straight to 100% and stayin gin the range. I can post those logs if someone wants. The two passages I have some success start at 50 and head to 10 and then stay in the 30-40 range. I consider any run valid as long as you are trying really really hard to win on every trial.
My current leaning is that chances are high that I am hearing something but it is really subtle. But my mind may change with more testing. I did not expect this. I thought if I heard something once I learned what to look for I would get a 9/10 run. But that never happened.
And no I am not acting like Kirk. Kirk reprogrammed because he couldn't face failure. I can accept failure but I still really really want to know the truth. I am very curious.
