lithiumnk
If you are installing first time then there is a slight learning curve. Afterwards, its a cake walk.Are the Dekoni pads that you recommend for the ADX 5000 easy to install?
I have compared HD800SDR with ADX5000 on my setup. There is a slight improvement in low end with attenuation of 6k peak.Btw, it does not come close to adx5000 bass performance.What would you say the difference is between an HD 800 with an SDR modification and an ADX 5000?
I could only find adapters so take a look at A4 / B5 / C4 hereDo you know any female connector to make adapters? I would like to share cables between headphones.
Congrats!I just made the jump to getting these after extensive demoing. What attracted me first and foremost is the sound - extremely fast and clear but I would also give props to AT for making the headphone so light!
Congrats!
What dac/amp are you using with adx5k?
Okay... you have made very good decision. Adx5000 is TOTL can. They scale very well.I previously only used IEMs so my source is basically just an ifi nano BL (for now at least).
Do try leather pads as i have mentioned in previous posts.
I had tried feliks audio echo, espressivo mk2 tube amps...it was wonderful...these make adx5000 shine...Yes I do believe a very good amp can make them shine even more so. I have heard them out of a Caiyin HA300 briefly and was definitely floored by the sound! Are there good pairings around the $1000 range?
Are you planning to build custom earpads?Can I get someone to measure the dimensions of the earpads on the ADX5000? Specifically earpad opening diameter, diameter of the full earpad, and thickness.
I am using Dekoni Sheepskin non fenestrated leather pads. Just mail dekoni for proper measurements. There was no mention of dimensions on the ear pad box.
