TooPoorForHiFi
Previously known as MidNighTempest
Any idea How they compare to the Dunu Titian 5s? Are these the Best IEM under $135? any better Alternative?
Ordered these, then ordered a pair of LZ-A4's after the 1More's had been shipped. However these have just arrived so figured I'd give them a listen while I wait for the A4's.
Compared to Shozy Zero's, these are incredibly comfortable and feel really solid and nicely built. Listening to Drake's "Controlla", the bass is also superb and has a nice "head shaking" feel to it. I'm really not technical at all but the 1More's just sound so clear compared to the Shozy's.
I'll see how I feel with the A4's but OOTB I'm really impressed with these.
I'm loving these things. I bought the NuForce ne800m and these to compare. These are soooo much better. I found that the ne800m had a touch too much sibilance and became fatiguing for me. The 1more triple driver never did this. Still had the treble extension just not the annoying part. I highly recommend these guys for the price. The bass is great and if that's what you're looking for I don't think you'll be disappointed. I still think the NuForce product was a little more comfortable. The tips that come with the 1more didn't fit me too well. I noticed that the bass drops off significantly when using the plastic tips that are included. I put the comply tips that came with the ne800m on these and it was definitely the best pairing. I ordered some comply tips to pair with these things permanently. I'm glad I found these. Well worth the price.
Can you tell me how is the stereo separation of yours? Because mine are not well separated.
I will do some further checking but at the moment it doesn't seems perfect.
