AtlanticProSnd
Banned for Moderator abuse
- Feb 10, 2017
Here is a comparison of the U12 through two different output sources. One with a low output impedance (CHORD Mojo). And one with a higher output impedance (USBPre 2). Notice the seesaw effect between switching from one source to the other.
The USBPre2 is not designed for low impedance devices (Bad comparison) Should have used Pro gear for this as that is what his claim is. USBPre2 is a preamp not a amp and not designed for low impedance loads. It's designed to drive an amp. It does have a Phones out for non-critical monitoring however the design of this device is to drive an amp or mixing console input.
Some of our products, the 12's being one of them, were designed for stage and studio use. Live performace and studio gear typically have higher output impedances. Thus the 12's need a higher output impedance if you're searching for a more transparent sound signature. Forgive me if I sound redundant at times I just wanted to explain the effects of output impedance for everyone to understand. I hope this helps you guys achieve the sound signatures you search for
Not true at all. I have worked in pro audio for 30 years and have NEVER seen any pro gear that has an output impedance higher then 2.5 Ohms (most are measured less then 1 ohm).
I believe its very possible that many of you that say the A/U12's sound "veiled" and that the B1 module fixes the veiling issue are using a low output impedance amp/dac and are compensating with a B1 module to bring down the bass and low mids... Which is what the B1 module was designed for. Thus balancing out the inherent response of the A/U12's through a low output impedance amp. For those who believe the A/U12 sounds "veiled" with the S1 module simply changing over to a source with a high output impedance will give you the desired sound signature... all without swapping modules. For some it's easier to swap a B1 module in instead of output source and that's a perfect solution as well.
The correct way to get the desired sound you like is to change out the modules which is what the modules were designed for.
