IPodPJ
MOT: Bellatone Audio
Caution: Incomplete customer orders
- Apr 17, 2006
x2, absolutely.
Originally Posted by catscratch /img/forum/go_quote.gif Depends on the rest of your system. It's pointless to get an HD800 if you only have a soundcard to drive it. If the rest of your system is weak, I wouldn't even bother with getting multiple mid-fi headphones, I would upgrade the rest of the system. Unless of course you don't like the headphones you've got now - then you should find something you do like, and then build a system around it. Hi-fi headphones are very revealing of system components and you will want to use them in a system that's as devoid of problems as possible. They're only a part of the equation, and you have to look at the whole. |
x2, absolutely.
