MattTCG
- Jan 22, 2012
May I ask the specifics about the power supply used in this amp?
It is a custom designed SMPS that provides +/-15V rails. What else would you like to know??
The jacks on Jude's proto were an earlier version and my best guess at what I thought people would want. But after a fair amount of feedback we changed the jack configuration to what you see now and what was at CanJam. I don't expect that any jack that is on there now will go away. If possible, I may add one more, but space on the board is currently at a high premium.
There are two 3 pin XLR jacks for the balanced in. There is one pair of RCA jacks for one of the SE inputs. There is one 3.5mm jack for the other SE in. The RCA and 3.5mm are connected together so there is really only one SE input and there is one balanced input, switchable at the front panel.
There is one standard 4 Pin XLR balanced output jack. There is one RSA type balanced output jack. There is one 1/4" (6.35mm) Single Ended output jack.
See discussions above for the difference in running Balanced out or SE out.
Thanks for the fast response.
I'm planning to go balanced and get the most out of my future equipment but the list of balanced connectors keeps growing.
Custom cables for each of my headphones would be too expensive so I plan to try some standard xlr adapters.
Is there any risk of damage to the amp or headphones if the pin wiring isn't exact?
Depending on how many cables you need, it might be cheaper (and more fun!) to get some soldering gear instead and make your own. I started down that road recently and it's been very rewarding. Now I look forward to getting new headphones with no balanced cable.
Still have a decent soldering gun but my soldering skills aren't quite what they were 20yrs ago.
Just searching for creative ways to get balanced out from my PM-3 and Z7 without breaking the bank (Sony's balanced cable won't work with the carbon and haven't seen a dual 3.5mm to 4-pin xlr yet). That money will be going towards amps/headphones anyway.
SE out is ok too (got a pure silver one for the Z7) but it'd be nice to go balanced if I can to maximize return on quality sound.
If you have a balanced cable for the Z7, you could snip the ends and rewire it to XLR. XLR is the easy mode soldering. :-D
