LaughMoreDaily
I bought the Topping NX1A on Amazon and I find it very odd that it doesn't tell you how to charge it properly. It doesn't even tell you anything about charging in the instructions.
You stick a micro USB charger in the hole which says 'charge' on it, when it's charging a red LED appears, I don't remember if it came with any instructions, it just seemed fairly self-explanatory.
Got a question, as I'm not very knowledgeable in the area of compatibility between amps and sources.
In terms of sound quality, would pairing my Fiio X3ii with the NX1 be considered as an upgrade, downgrade, or neither?
If it is any help, I mostly use low impedance earbuds.
First question is do you need an amp? If you're using low impedance phones that can be driven well by the X3ii then I wouldn't bother. Only those with an X3ii could say if using it in line out with this amp makes any difference, my guess is probably not or certainly not favourably.
This probably will sound odd, but thanks voxdub, for reminding me that I bought the fiio x3ii to use it as a sole player without the need for an amp.
Was still wondering if the nx1 could help further smoothen the sound, but honestly I'm doubting it too.
Cheers, mate.
Hi, guys!
I'm planning to cop an NX1A one of these days and pair it with my Benjie S5 with the use of Fidue a73 and Dunu DN1k. Do you guys think it will pair up nicely with my setup or there will be that hiss/distortion that some of you have mentioned?
Hiss/distortion comes mostly from interference using it with a smartphone. I don't think you will have this problems with a Benjie.
Coming late to the party - my Fiio A3 died on me after 4 months. Luckily I could convince Amazon (UK) to accept return for full refund. Though I liked the A3 I was so disappointed with its dying, that I looked around for something else. I ended up with the NX1A - cheaper than the A3, so for the refunded sum Icould even buy some small bits and pieces.
It arrived today, the first impression is very good on this setup: Sony NW-A35 -> Fiio LOD cable -> NX1A -> Senn HD-598
