fearlessleader
- Dec 5, 2016
Thanks. Will now try for cp240.
Did a bit of tip rolling again with my Westone UM 30 Pros. the sound with the Star Tips is really outstanding but I just
can't keep a good seal with them, went back to my CP800s and I'll gladly trade a bit of bass for the better fit.
I can't get the twin blade (CP240) to seal well so I'm not using them, probably need to order a larger size.
Both the Star tips and the Spinfits give a good clean treble with no roll off.How would you compare the star vs spinfits on the um pro for treble? With foams, it's just too severe of a cutoff,
I had to use the big orange star tips. Of course they don't stay put as well as I'd like.
Thanks. The Spinfits that came with tithe Sabre just won't fit onto a Master filter. If those are cp100's that's 3.8mm.
Their drawings at https://www.spinfit.tech/copy-of-single-umbrella shows the cp240 to be the narrowest twin blade at 4mm nozzle but cp220 is 4.4mm and cp230 is 5.5mm. I don't know the OD of he Master filters, but will try to measure them tomorrow.
Since you are currently using the large size CP100, I would try out the large size CP240 first. Try the medium out afterwards if the large size doesn't work for you.Hi, i'm interested in the twinblade cp240 for my ath-im03. how do i choose which size to get? should i look at the small umbrella or the big umbrella? currently i'm using a large size cp100
thanks for the advise moedawg, still hesitant as its quite costly to try.Since you are currently using the large size CP100, I would try out the large size CP240 first. Try the medium out afterwards if the large size doesn't work for you.
I understand. If you live in Southern California, I'd be happy to let you try out my tip lineup (including SpinFit(s), Final tips, etcetera). If not, maybe there is a Head-Fier near you that can let you try their double flanged SpinFit tips.thanks for the advise moedawg, still hesitant as its quite costly to try.
You can always order both the Large and Medium sizes, and then give away or sell the size that doesn't fit you.
Happy to offer assistance.Thanks for the offer, i'm afraid we live too far apart. i will definitely pull the trigger but not that soon. still trying to find a way or place to test it or wait till the price drop or get it at aliexpress during double 11 (lol, long wait away).
