- Aug 15, 2011
Thx to @Arnaud's influence, I've joined the party. Great earmuffs during winter too.
It's an intrinsic problem in ANC because soundwaves themselves are made of changes in air pressure. The ANC microphone picks up both audible noise and sub-bass pressure changes and it is up to the implementation to distinguish between the two. Some ANC headphones are better than others at filtering out sub-bass pressure changes, but it could be a tradeoff at the expense of noise reduction effectiveness. If your ears are very sensitive to the effect, you might want to take a different route such as headphones with high passive isolation.
Question is....will I get the same problem with the QC35's?
can anyone link me to a cable with mic and volume control that will fit 1000x from amazon.co.uk ?
You need a cable with extra ring on the jack( or long jack) to make it fit.
I have some aux cables with and without remote and theres an angle on the earcup that makes some not fit.
Cable from my mdr1a fits, but i would like a 3 button one so im also looking for it. Could always remove the jack housing on existing cable also.
Please do link me if u found the cable ur looking for
heres one
http://www.ebay.com/itm/201532779765?_trksid=p2057872.m2749.l2649&var=500724213913&ssPageName=STRK%3AMEBIDX%3AIT
I have used that seller before.
I ordered this one for my ausdom m05 or other headphones. great quality at unbeatable price but does not fit.
You could probably file down the jack housing to make it fit.
https://www.aliexpress.com/item/Remax-3-5mm-Universal-AUX-Audio-Cable-Male-To-Male-Jack-With-3-0mm-Speaker-Cable/32755324660.html
Can anyone give me a report on the bluetooth calling sidetone performance of these headphones? With full cover cans it's important to be able to hear your own voice while speaking on a call. Does the ambient voice feature take care of this if enabled by letting your own voice back into your ears? Do these ambient sound features work at the same time as your on a call?
Other than that I'm sold on these 1000x. Thanks for any info.
i recommend trying the PXC550 I use a pair on the train daily without this issue whereas my pair of 100ABN have the same issue your describing.Tried for the last time today on the commute, but it's far too distracting, so they are going back. Question is....will I get the same problem with the QC35's? Anyone had that experience? I never used to get it with my old Bose on ear NC cans
if call quality and side tone are important to you I suggest checking out the Sennheiser PXC 550.Can anyone give me a report on the bluetooth calling sidetone performance of these headphones? With full cover cans it's important to be able to hear your own voice while speaking on a call. Does the ambient voice feature take care of this if enabled by letting your own voice back into your ears? Do these ambient sound features work at the same time as your on a call?
