Brudda
- Jan 15, 2015
Wave sounds, help me please, I'm lost
what do you mean i got the wrong pads??
you have the non angled pads ? what's the difference between the two, angled and non angled?
with the non angled pads ( like yours) do you have the same sound quality ( bass, treble, etc) like with the stock pads
So, i have those ones
https://www.amazon.de/gp/aw/d/B01IR3PSL2/ref=ya_st_dp_summary
angewinkelt.... means... angled
beside comfort, do you lose sound quality with those I have?
Thanks
I'm betting they will sound near identical to the non-angleds of the same material, so no worries there. The only concern I would have is if they fit well (ie, do they completely seal around your ear). If they do, then you're good to go, imo
