fatbenjamin
Guys,
is anybody using a Sandisk 200GB card with the M2s? Just curious if that works or not..
Thanks in advance.
Hi,
Yes I have one of those in my M2s and it works fine.
Guys,
Thanks in advance.
Yes. I also think the screen is darker, almost like the gamma has been played with.Hopefully they get back to you quick, you know whats weird? I swear my screen looks a touch darker than the previous firmware on the same brightness setting, might be a power management tweak or I'm just hallucinating.
Besten DankIt works. I am using exactly that. Why wouldn't it work?
I have helped quite a few guys at the Shanling booth with any questions they had about this great player. Was good to see many being sold and new happy owners.
I can't recommend any other music player at this price point, so Shanling did a wonderful job delivering so many features in a small player that's affordable to anyone.
Any update on this yet? The M2s is proving to be a fantastic little device and I'd love to be able to make some themes for it
Then look at something like the iDSD BL. You're not gonna find that type of quality in a DAP...not yet anyways. But, having said that, the M2s is GREAT as a stand alone, as well as a source for using an external DAC like the iDSD or Mojo
realized today the M2s doesn't pause playback when you unplug your earphones. Maybe to be considered for future FW
trying to use my M2S with Hugo 2 apt-x
is there no way to get the M2S to output line-level when using BT? i have “LO” chosen in the settings but the volume knob still affects the output
alternatively, what volume # setting would be good for line out?
sounds great though!
What's the changelog on fw 1.20, can´t find any info besides the polish and german languages fixs.
Hi guys,
I have a problem after new firmware update. My screen when turned off (screensaver) and I want wake up the screen I have seen nothing. I mean I seen something similar like on the TV when no signal. After switching off and back again on it's working, but as soon the screensaver turns on the issue repeat itself. I have upgraded twice the firmware and I went from the 1.10 firmware. Oh, and sometimes the screen working fine. Any idea @Shanling what cause this problem?
Guys,
Thanks in advance.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Will report to our engineers to see what can be the problem
Well, are you sure about this? Because both of my M2s both pauses automatically after I unplug headphones.
@Shanling I'm having problems upgrading the firmware from ver 1.2 to 2.10
I copied the update.upt file to the root directory of the memory card, from System Settings/System Upgrade, clicked the little tick mark in the circle, I hear, what sounds like a reed switch click, the screen blanks the switch clicks again and the screen returns to the desktop without upgrading and without any failure notice.
I have downloaded the firmware four times from two locations, from your website and the Google Drive link you provided earlier. I have tried three different memory cards. Following several failed attempts I reset to factory and tried again. All without success.
What do you advise?
Try this:
Turn off the device, then hold the play/pause and power buttons for 10 seconds. That'll force the device into update mode
I had updated from 1.2 to 2.1 and everything goes perfect, have a new option about fast roll off filter but honestly I don't feel any sound difference changing that option. Maybe it's something in my imagination but the player seems to be less hot during play.Anyone went to 2.1 from latest hiby link beta? Issues? It's recommended to update from 1.20 to 2.1?
Back from some holidays+vacation, now back to threads!
HiBy team is working on iOS version, hopefully will be out soon, but I have no more info right now.
I will definitely stop by Chord table at Canjam London and test it out! With photo proof.
Noted here. There is a lot of people asking for a lot of functions, we must consider what to add and what not, since we don't want to end up with menus over three different screens.
Can you pelase PM me with more informations regarding your problem? We have some tools to fix any software problem.
Will look into it.
I recommend using charger from smartphones. I use mix of chargers from Asus, LG and third party and all works without problem.
So glad you enjoy our player!
We are looking into adding some functions to volume wheel, but not sure if we want to double up on already existing buttons.
Well, there are some limitations of HIBY UI, will see what can be done.
Just released M1 firmware 3.0, which features digital filters, so there is chance for you
Thank you for review! And I hope we will make you more satisfied with future updates.
Thank you for nice review! Need to promote it here again, so it doesn't get lost between interesting watch discussion. )
