JimL11
A look at the specifications in comparison to the SRM727 does yield some useful information. Between the two, the maximum output is almost identical, 450VRMS for the 727 vs 470VRMS for the T8000. The power consumption is 46 watts for the 727 vs 58 watts for the T8000 w/o the 4th slot plugged in.
So what can we gather from this? Well, the max output tells us the voltage of the power supply. In the 727 it is +/-350 volts, so it is nearly the same in the T8000 - say +/-360 volts. The T8000 draws an extra 12 watts, however the input tube's filament supplies use up an extra 5 watts, and the input tubes like to run at a higher current and voltage than the solid state input section it replaces, so that probably accounts for most, if not all, of the additional power draw. Overall then, the output stage should be pretty close to the 727 in both voltage and current output capability. It should be nearly identical to the KGST in voltage output but with somewhat less current capability, but it does not approach the voltage or current output capability of the KGSSHV, KGSS Carbon, BHSE or DIY T2. Now, these limits are somewhat academic in that playing music at those levels for any length of time will give you a nice case of permanent hearing damage, but still....
The interior shots do not appear to show the presence of a regulated power supply. Not all amps have a regulated power supply, but the presence of one would result in an increased parts cost and an increased price.
So, if it is not significantly more powerful than the 727, and does not have additional circuitry for power supply regulation, it does raise the question of why it costs three times as much as their previous TOTL amp.
