WindowsX
Member of the Trade: Fidelizer Audio
- Apr 27, 2007
Delicious!
Delicious!
Very nice looking!
Dear Keetakawee,
If I want try the latest official rom, and then back to your latest advanced rom, i need to choose 'recover' or 'upgrade' in the factory tool for your advanced rom?
Thanks.
I think you need to use the flash tool that he links in to OP. Try it both ways and see what happens. No harm no foul right?
Delicious!
Hi WindowsX.
let me tell about your mod.
what did you change?
thank you.
Any update on new advanced FW?
EDITED: What a coincidence, you reply just before I click send the reply only few sec.
You can read my mind xD.
All capacitors replaced with highend grade ones tuned for better sound quality. Opamp was re-engineered with new opamps set for better sound quality with high power output capable of driving full size cans.
Regards,
Keetakawee
nice!
Could you tell me the name of the replaced opamp?
thank you.
come on...friend.
so, which type can we put on ?
single or dual?
and THS4631 can be installed on it?
It uses dual so single opamp THS4631 won't fit. Maybe you'll have better luck on AMP2 if they use single opamp there (no balanced output though).
