Tim Le
- May 11, 2017
IMO, you won't get M50x level of bass in an open back headphone. The X2 is open back. I had them. They are quite bassy for an open back, but my 2 big issues with them were comfort (tight clamp) and a certain shrillness or harshness to the treble only evident on some songs. I preferred the M50x to the X2 both in terms of comfort and sound. YMMV.
Have you considered Beyerdynamic DT 770 or DT 990? The DT series are very comfortable IMO. The 770 is closed back and 990 is open. Both have a good amount of bass but maybe not as much as M50x, especially high bass. The 770 being closed back should have better low bass than 990. If you decide to try either of these, I'd stick with 80 Ohm ones or higher. I read that the lower ohm models (16, 32) don't sound quite as good.
I have also heard good things about the Bose Soundtrue Around Ear II, both in terms of sound and comfort, but never heard them myself.
There are many other headphones out there with the bass of the M50x or better, but not many with also the same comfort as 598.
Edit: Forgot one. Sony MDR-1A looks like it might meet your criteria of comfort and bass.
Wow, can't believe I forgot about the Beyerdynamic offerings. The DT990 is the most comfortable pair of headphones I own; the bass and soundstage are both excellent. I think they're very hard to beat under the $150 price range. The midrange is slightly recessed, and some people find their treble too bright; you can take the extra money saved and buy a warm amp.
As a bonus, they're built like tanks. I've had my DT990 for over 3 years and haven't had so much as a hiccup.
