PanzerIV
- Aug 19, 2009
Wow thanks, that was fast! I will give it a try if I got some time tonight, else very soon this week
Guys i recently bought a fiio x5 1st gen. Im currently on V2.35 (if i remember correctly). i have not faced any major issues or freezes yet, but i did notice few very small duration pauses while playing songs(dont know what you call it. It's as if your record is stuck for a fraction of second) . Is upgrading to 2.5 adviced? I mean, are there any issues that plagues the version V2.5
FW 2.5 is the most stable version. There's a new beta FW out (2.51beta) but there's an issue with the screen going to sleep.
Out of curiosity did you turn on gapless playback in the Play Settings menu?
did you ever find a workaround for fw 2.5 and linux? i had the same problem as you and reverted to 2.4. now i'm trying the new fw 2.6 and having the same issues as with 2.5, figured it was worth reaching out to you to see if you'd figured it out. i'm back to fw 2.4 for the time being, just so i can keep my linux dac functionality... thanks, -josh
So great... yesterday during the cold winter in Canada, I've moved the small usb cable inside my car that was charging my X5 and I guess it must have messed the port even though nothing seems loose as now the X5 won't be detected anymore on my computer and won't charge anywhere... is there anything I can do or I need to throw this 350$ unit in the garbage because Fiio makes cheap 1$ usb soldering? (-_-)
Hi, PanzerIV.
For your X5, not matter the Storage or DAC mode, it could not be recognized by your computer? Here is a special firmware for the X5, and pls try to upgrade your unit and test again. Any test result, pls let us know.
Originally Posted by PanzerIV /img/forum/go_quote.gif
Hi Shadow and thanks for your help but there's nothing I can do as now, no matter where I plug my X5... computer or any wall/usb outlet, it doesn't even start the X5 anymore and there is no green or even red LED at the bottom like there was before.
It's exactly as if nothing would be plugged at all, zero recognization suddently since yesterday and I haven't done anything strange to the player, I even always take highly care of it as it's either in my pockets, sitting on my bedroom's desk or on my passenger's seat while I drive, that's it! So that really makes me mad that such an expensive player dies out of nowhere in less than a year from such a dumb issue as if I cannot charge it anymore then that means I won't be able to use it at all in a few houres as now there's only 2 bars left on the battery -_-
Is there a way I can get the player exchanged on warranty in CANADA since it's been less than 12 months? Hopefuly it could then be changed for the newer "v2" version... please let me know as soon as possible as I'm gonna die without my daily music argh.
Hi, PanzerIV.
Hi, PanzerIV, in this case, i think the x5 is faulty. Pls send email to our support team(support@fiio.net). They will help to solve this issue.
