superuser1
Just received my KZ ZS5's and my they do sound very nice out of the X5III
I did look at them on aliexpress... looking forward to a more detailed impression.
If really equal, equalization would be the cheaper wayYes or just eq a bit more treble on the X5III.
Same here with the iBasso PB3. I really don't like the sound of the x5iii without it.I definitely recommend A5. Just generally sound more clean than stock.
What headphones or IEMs do you plug info the X5 III/A5 combo ?
I have Fitear Togo 334, not shure if A5 woukd bribg something...
I am actually looking into getting the LZ A4s soon, for my X5iii, ive heard very good things about them.Saw your post, sorry this is a little late (I'm on holiday in Thailand!!!) Don't have the Elear but do have the nighthawks so tried them straight out of the X5iii. No.
At low volume I guess they sound OK but lacking body. At higher volumes (not loud, just medium) the deficiency in driving force is very apparent. Real lack of bass and lower mid body, slight distortion overall. For me, I would definitely want an amp in between the two.
Perhaps unrelated, but LZ A4s sound lovely straight out of the X5iii.
Hey Cheaplad Im gearing up to make the exact same set up you seem to have. I currently own the chord mojo, and a fiio x5 first gen. I want to upgrade to the fiio x5 third gen, but I have some concerns that you may be able to answer. On my first gen fiio when outputting to the mojo whenever a song's sample rate changes the mojo skips the first two seconds of the track. Does this happen on the fiio x5-3. Also is the UI competent? The reason I want toe upgrade my fiio x5-1 is because the UI is abysmal.I connect the X5iii with Mojo using USB cable and it works today! Oh sweet thunder!
Bought a pair of these iem's and totally love them, took the place of my trinity vyrus ii.I am actually looking into getting the LZ A4s soon, for my X5iii, ive heard very good things about them.
Dear friend,I have both the X5 first gen and now the X5 3rd gen. I currently cannot use the Mojo with the X5iii as all sorts of horrible noise gets added when connecting via coax. I am told you can't use USB to connect to the Mojo at this time but I haven't bothered to try that. The original X5 works like a champ with the Mojo, with no real drawback in comparison to the X5iii. I am very sad about the X5iii being a step down from the original X5 when using the Mojo. It wasn't always this way, just with the latest firmware. I would not be in a hurry to "upgrade' if I was you.
(And i would be totally fine if things worked swell for others and this is just a personal problem I have. But I don't think that is the case)
Dear friend,
You can't collect the X5III to your mojo via coaxial collection? Have you used the correct cable? We did tested the coaxial output to Mojo should be fine.
Best regards
