Lurk650
Can I use the fiio e07k dac with Apple nano 7g via lightning USB adapter and mini usb?
You need the CCK, camera connection kit, bestbuy sells it for $30, that plus the FiiO L9 will work.
The nano has a lightning port, which camera connection should I get to utilize the e07k dac?
When using it via USB whether computer or like I do where it's Line Out from my 4th Gen Touch it uses the DAC and amp. If you just use a 3.5 to 3.5 from headphone out to the FiiO then it acts as just an amp.
could any of you comment on the soundstage and imaging of the Andes and if it is operable with android?
Wondering if repair on it can be made ?
I am about to buy a second hand E07K . Did anyone have issue plugging it on a 6.0 running android phone (2014 MOTOX)
I have had answers from FIIO customer service and they say that none of there DAC's are Android compatible. That Android is unstable and that a simple upgrade could make it not work...
