Has anyone tried 6 X EL3N on the Euforia yet? How does it sound? Is there still hum as the case on some Elise?
Hi Richard,
I've not fully responded to this and I will now. A bit of background for those unaware.
I was the first to try 6xEL3N on Elise after consulting Lukasz. I remember his response when I send him the photo of Elise with those six EL3N mounted with 2 sets of adapters. He had quite a bit of shock, as well as amusement. He wasn't angry but was quite surprised that it work as I told him. His dad Henryk, took a look and started pacing the room. When he did return to the photo, he mutter that 'it might work with the right adapter' with the usual caution, 'you do so at your own risk'.
That begun a long period of my love affair with 6xEL3N and the many pictures that I post of it on the Elise thread.
Fast forward to now, I've totally given up on non recommended tubes by Feliks Audio. Why? Because just after I received my Euforia, Elise's left channel became almost muted. I took a look at Elise bottom and through the vent, I could see that the PCB board and circuits were quite roasted. I then send Elise back to Poland to be renewed. My instructions to Lukasz was to make it new again. Make it new they did. They changed everything except the transformer and chassis. My Elise became an upgraded Elise, closer to Euforia then the original Elise.
I then ask Lukasz what happen to my Elise. Lukasz confirmed that the circuits were fried and that the only explanations were using non recommended tubes that over heated it, over a period of time. I had my Elise for 1.5 years and in that time, I use it heavily everyday.
Now I have use a lot of non recommended tubes but never any Christmas tree setup. Never any bizarre setup apart from 6xEL3N. It may not even be due to 6xEL3N. It could be the 6N7G that I use heavily at one time or ECC31. Remember Elise allowable current range is 6 to 6.5a. Lukasz told us so himself. It was not a figure pluck from the air.
Using 6sn7 and 6as7:-
2x6sn7 = 0.6x2 = 1.2a
2x6as7 or 2x6080 = 2.5x2 = 5a
Giving a total of 6.2. <--------------------- very safe point in the allowable 6 to 6.5a
Using Mazda 6N7g and 6as7 gives:-
2x6n7g = 0.8x2 = 1.6a
2x6as7 = 2.5x2 = 5a
Giving a total of 6.6a <------------------ now we're 0.1a over the allowable ampere range. We could argue that over by 0.1a is nothing but how would we know, when using this over a long period? This is what Lukasz is trying to point out. It might be ok for a short period but the life of the tube amp will suffer over the long period. That's what he said.
Using Mullard ECC31 in Elise is even worst.
2xECC31 = 1x2 = 2a
2x6as7 = 2.5x2 = 5a
Giving a total of 7a <------------------- We assume that this is allowable. Yes big assumption here when the manufacturer told us specifically that the allowable range is 6 to 6.5a. We took the liberty in our wisdom to think that 7a is OK. Over the long period, a fried circuit is what's coming which is what happen to my Elise.
Right, that was a lengthy write up but one that I must expand on. So after Elise came back and having gotten a new Euforia, I thought to myself. I am going to make sure these tube amps last a very long time. They should go for 10 years without problems if use according to manufacturer's guidance. That's when I took the extra-ordinary steps of banning myself from using any non recommended tubes, including the ones I like most, including the ones I paid a lot of money for, including the ones I wrote pages and pages of praise. Nope I wasn't going to use any of them if I am unsure which ones did fry my Elise internals. If I wanted to keep my upgraded Elise and new Euforia for a long time, why take any risk. Why disregard the manufacturer's recommendation. These amps aren't exactly cheap, especially Euforia at $1399.
Was 6sn7 and 6as7 not good enough for Elise and Euforia. A big NO. These tube amps sing beautifully with 6sn7 and 6as7 and why would that be surprising.
They were specifically tuned for 6sn7 and 6as7 and not others. FA did not create a super amp to accept all kind of tubes.
If Lukasz had a voice here, this is what he would have said so himself.
Cheers and enjoy Elise and Euforia for a long time,
UT
