vapman
Member of the Trade: bhobuds.com
- Aug 14, 2006
@Ira Delphic link? There are like 100 different sounding mx500 clones on AliExpress so i'd be willing to bed it is a mx500 inspired driver in a mx500 clone shell.
Awesome mods Ozkan. Where is the best source to buy she3800? I see only iems when I search.
As for the mods you did on them, is that just cotton and a blob of bluetac? I did similar mods to my Foster t40rp. Have not tried on any earbuds.
32 Ohm version:
http://www.ebay.com/itm/Sennheiser-MX500-S-DIY-upgrade-bass-HiFi-In-Ear-Headphones-Earbuds-silver-cable/302056584157?_trksid=p2045573.c100507.m3226&_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D38530%26meid%3D5cc3e2bb994048e4b42c29e7baa108e9%26pid%3D100507%26rk%3D1%26rkt%3D1%26
This is the 300 Ohm version -
http://www.ebay.com/itm/Sennheiser-MX500-T-DIY-upgrade-bass-HiFi-In-Ear-Headphones-Earbuds-Twisted-cable-/302090057713?var=600901251924&hash=item4655f877f1:g:nJsAAOSw8w1X7GUO
Whoa that is really cheap. Great mod platform. I will definitely have to order a few. What size drivers do they use? That would be a perfect candidate for recabling practice. Going to order 3.
Looking forward to trying your mods Ozkan.
The easiest Monk mod:
The green thing in the middle hole is Blutac. By adding a tiny bit Blutac, the soundstage expands, the mid-bass tames a bit, more laid back mids and subbass gets more prominent.
Just grabbed some blu tac off the wall and tried it on my Monk Plus.
Lower bass improvement is most noticeable, as well as tighter mid bass. Some lifting of veil around upper bass/lower mids, but seem to only affect quite a narrow band. Voices are slightly lifted, but warmth/veil still layers over the performance. Bassheads should be happy with this blu tac trick. Vapman should try this on his monk plus, which he already like in the first place. I am leaving the blu tack on, as it then requires less extreme EQing to make it more suitable to my ears.
Thanks for the tip.
I posted this in the earbuds thread first, but it might belong here...
Does anyone know how to "open up" plastic that has been glued together?
I'm thinking of recabling the Aiwa V99 and I need to open them up. There is like a small lid or hatch on them that you probably are supposed to open for access to the cable, and that has been glued shut.
It can be seen in this picture:
(I found this photo online)
I'm thinking of using a thin razor and cut along the edges of the lid/hatch but that might not be enough.
The soldering part itself shouldn't be any big problem since the previous owner left about 2-3 cm of the original wire soldered onto the drivers and then I only need to remove the wire that the guy soldered on and solder the new wires onto the wires connected to the drivers.
But getting the cable into the housing, heck even getting access to the housings, seems to be a big challenge...
I got some good advice, like using a hair dryer to make the glue warm and easier to get through.
