DIY Cable Questions and Comments Thread
Jun 28, 2017 at 8:50 PM Post #7,171 of 10,535
Jun 28, 2017 at 9:15 PM Post #7,173 of 10,535
Which is better, Mogami W2791 or W2549 for making home made short, unbalanced interconnects?
Either would be fine the 2791 is 24 awg and the 2549 is 22 awg so not much difference I tend to go big if it will fit the connector. That is just me YMMV.
Jun 29, 2017 at 12:24 AM Post #7,174 of 10,535
Jun 29, 2017 at 12:38 AM Post #7,175 of 10,535
You should find some smaller gauge wire. Looking at the conversion table and that makes it 19 awg so a 8 wire braid would be pretty big.
So .05mm is about 44AWG. 100 strands of that is 24AWG according to https://www.v-cap.com/awg-calculator.php
Given that the overall diameter of the cable is .9mm, 24AWG seems generous. An 8 strand cable of this wire should work well
The lack of specs on the wire, and its low cost probably indicate a very small silver content, and less than pure copper.
Jun 29, 2017 at 6:50 PM Post #7,176 of 10,535
Just to put the size in perspective, 0.90mm OD is smaller than a single conductor in Mogami 2799, which is 1.0mm OD. If unbundled Mogami 2799 can make an 8-wire (too scared to try), then that lunashop one should also be able to.
EDIT: Ninja'd
Also @Minatect , that 100 strands is misleading as the individual strands are bundled into 7 larger "wires". I think this would make the cable less flexible than a straight up 30-strand "wire".
Jun 29, 2017 at 6:57 PM Post #7,177 of 10,535
Yes it is od didn't look hard enough. Yes I think the bundles would make it less flexible. Still think 4 strands of 24 awg is pretty big for a iem connector.
Jun 29, 2017 at 8:18 PM Post #7,178 of 10,535
Luna Shops even suggests making an 8 strand braid. For $32 it's certainly worth a try.
except that it's lunashops, which generally suck.
Jul 4, 2017 at 12:26 PM Post #7,179 of 10,535
How thick of a cable is acceptable? I'm going on 4 braid with paracord and I think that it is just nice but I see some of you guys going 8 braid with 24AWG [same size as me] won't it be bulky? I am tempted to try it tho
Jul 4, 2017 at 6:02 PM Post #7,180 of 10,535
I have a sixteen strand with a very tight braid (no paracord), and it's a little bulky. To me the 8 strand is perfect. The challenge with a 4 strand is not having the cables between he Y and the tips unravel. There is no braid with 2 wires; there is only a twist.
Jul 4, 2017 at 7:56 PM Post #7,181 of 10,535
Yea the 2 wires was my initial worry too but apparently, I read somewhere in here stated by someone that twitsting the 2 wire tight enough can have a good lasting bond and it does work!
Jul 5, 2017 at 1:15 AM Post #7,182 of 10,535
Thanks. I purchased some silver plated 24AWG wire and plan to make a 4 strand for the Ether C. I will sleeve with 95lb paracord and try the twist.
Jul 5, 2017 at 9:16 AM Post #7,183 of 10,535
Good luck!!
Btw I had some wild idea thinking to apply but not sure if it will work. To have a stronger bond on the end of the 2 braid, perhaps u cn burn the end of the cable that can bond the two cable together further and also to avoid further tearing the paracord apart by natural use but never dared to do it as I am worried it might burn the cable too
Also, make sure to straighten the 24awg cable as much as you could before sleeving into the paracord, it will in all the way and just one push!
