butch111
- Feb 26, 2017
NFB 28.38 arrived - but sounds like i have to burn in for a while
Alternative fact.
NFB-1AMP. NFB-28 is the best option for most people, but in your circumstance you should get a dedicated amplifier. It doesn't make any sense to run a lineout from NFB-28 to a low output-z portable amp just for IEMs in a desktop setup, it is suboptimal. If you listen to low impedance IEMs only occasionally, and can handle the slight bass bloom, I would still get the NFB-28.
In most cases the rationale for getting a NFB-1AMP/C2 can be boiled down to three reasons:
1. You already have a DAC that you will be keeping
2. You need lower output impedance or extra power
3. You want discrete units that you can swap out
Likewise, for the AIO units like the NFB-28
1. You want a compact, monolithic unit
2. You want to save significant money for essentially the same sound quality (unless this conflicts with #2 above)
As for the Gustard X20, if my X12 was any indication, it will be even better. But if it were up to me, I'd just get something with a similar form factor like the NFB-1.38 and just stack it to save space. The older Audio-GD DACs had a ghetto USB implementation, but the newer stuff actually has good USB implementation. The chronology was Tenor -> Amanero -> XMOS, and I called XMOS way back then, and they made the switch to it a few months later. One of the reasons I didn't get an AGD DAC was due to the mediocre USB, it was apparent even back then that while Amanero was cheaper, it didn't have the same wide adoption or continuous development as XMOS.
Thanks for the advice and information! It's a lot to think about.
I think I've decided to hold off on the 28.38 for now, and see what options start popping up over the next year. I think separate units ultimately make more sense for me. Especially if the X20 is a better DAC anyway.
I'm considering both X20 and the NFB28/28.38 as well.. Wonder from where do you think X20 has a better DAC? Seems X20 is using ES9028 while NFB28.38 is using ES9038.. Isn't ES9038 a better chip? Or are you comparing with NFB28 only?Thanks for the advice and information! It's a lot to think about.
I few people suggested as much in this thread. They may have to weigh in on this.
Here is my guess: The 9038 is the better chip on paper, but a great deal depends on the implementation. This may be where the Gustard pulls ahead, as it is a dedicated DAC, rather than one that shares key components with an amp. I also am a bit frustrated by the lack of detailed, updated measurements for the 28.38. Tthe Audio-gd page shows the same specs as were posted for the 28. Surely some of those specs must have changed...
For me, being a better DAC (if it is) is a secondary consideration. I am more concerned about the output impedance of 2 ohm and having to open the case to change digital filters.
I just got a used NFB-28 in, with the 9018. It's great, Actually replaced my C-2 and Bimby. Time to sell my old gear...
I'd like to hear more about "C-2 vs NFB28 as an amp" and "Bimby vs NFB28 as a dac"!
