jdoe
- Mar 15, 2014
I'm also using the E3 together with my ASG-1. There a clear difference when its plugged into the computer, but SQ via my iPhone 5s bluetooth is not as good as wire
How do you know if my Android Note 10.1's bluetooth is using APTX? I know it supports it, but is there anyway to know if it was successfully applied to the connect?
Anyone did any pure audio DAC comparison between the E1 and the E3? I will mainly be using it with my surface pro as a DAC when I visit starbucks and travel, but being a portable amp for my iphone is a huge plus. Currently I am using the Asus U3 as my daily portable driver, but I want something that can be used as a portable amp for my phone.
Is the E3 just a bluetooth added version of the E1? Thanks
No, E3 isn't just a BT version of E1. The two actually has very similar amp section that based on the same chip, but the DAC section are different as E3 uses the PCM51xx from TI while E1 uses the all-in-one Conexant CX20562 codec. As far as DAC goes, E3 is better.
Thanks for the very useful information. E3 it is then. Do you think it would be powerful enough for a 150ohm headphone like the sennheiser HD700 or should I move all the way up to the E5 for that for portable use.
hello,
i have a question about the e1, can the onboard mic be used when IEMs are plugged in and the E1 is not plugged in to a pc?
I'm looking for something that will do the same job as the no longer made Shure push to hear module
https://www.head-fi.org/threads/shure-push-to-hear-pth-module-only.678602/
