Westone UM3X Thread
Mar 15, 2010 at 5:29 AM Post #2,911 of 4,413
Hmm well many seem to think that. Their specs on westone's site are the same as well. I would imagine they do use the same drivers, even though the ES3X cost twice as much.
Mar 15, 2010 at 5:33 AM Post #2,913 of 4,413
Well then epic win of course! http://www.head-fi.org/forums/f103/i...earing-454174/
Can pay $80 (roughly) and get them into custom molds. $460usd vs ES3X $800 (I think) is great
Mar 15, 2010 at 10:30 AM Post #2,914 of 4,413
well the main difference is that, while the drivers are the same, they are tuned differently for their respective shells ( custom and universal ). So at the end of the day buying a um3x and having it re-shelled wont be quite the same as getting a ES3X, as your setup is for universals and not customs.
Mar 15, 2010 at 10:33 AM Post #2,915 of 4,413
Yeah, I figured it would be something like that. But hey, I don't want to be buying a new pair of comply's or anything like that constantly, as they are expensive and won't give as good of a fit as a custom shell will
My next IEM I hope to be is the JH 13 Pro, but the UM3X is good enough for now.
Mar 15, 2010 at 10:51 AM Post #2,916 of 4,413
but having said that, im not against someone trying it! ive thought about remolding mine as well.
Mar 15, 2010 at 10:53 AM Post #2,917 of 4,413
I might sometime soon. It will lose a lot of resale value probably, that's quite a big problem for me.
Mar 15, 2010 at 2:50 PM Post #2,918 of 4,413
I used to consider this too. Then I got my first pair of customs (JH13s), and they really aren't as comfortable as the UM3x. If you had something like the IE8s, which is hard to get a good fit for, I'd understand. But with the UM3x, the fit is perfect and so comfortable, it just doesn't make sense.
Mar 15, 2010 at 8:57 PM Post #2,919 of 4,413
I get a horrible fit with mine. I use the small comply and it stays perfectly in my right ear but isn't that comfortable, and the one in my left ear canal is loose and I have to move it around to get good sound out of it. I can't get half of the standard comply into my ear canal, I dunno how others can, that's crazy.
Mar 15, 2010 at 9:03 PM Post #2,921 of 4,413
Well I am broke now and will be for a while I think. I planned on buying a pack of Shure olives, but at $30 or so a pack, they aren't cheap, especially considering I have no idea which size I need to get.
Mar 15, 2010 at 9:06 PM Post #2,922 of 4,413
Have you tried the "mushroom" silicons (the gray ones)from Westone. I have small ear canals and the small ones sound and fit great for me.
Mar 15, 2010 at 9:07 PM Post #2,923 of 4,413
One day when I get rich I will. All these damn eartips, It's going to take me months to save up and try each one to see which one is for me. This is the reason why going custom would be a good option.
