parabellum777
Thank you so much for your answer.
Yes, they have removable cable.
I tried different cables, but I was not able to make it work. Maybe the problem is caused by the MMCX connector part which is in the earphone side, but I don´t know how to check it. I opened it to try to find a disconected cable, but it seems that everything is ok.
I wish the distortion stops after some time of use, but I´m skeptical. It starts at normal volume and it is very noticeable when the volume is increased.
On the other hand, I only use Comply Foam tips.
UM3x is 7-8 year old model, it's amazing if you have been using it for that long and it's still working great! Btw, I love PICO, reviewed it on HF; too bad it doesn't get as much attention, plus Lotoo killed fw development so no English updates I assume you got UM3x RC with a removable cable, right?
With UMPro30, early batches had issues, as it was noted before. That's probably what you have. With right side not working, did you try to spin/turn the mmcx connector, to make sure it's not loosing the contact? How about switching Left/Right sides of the cable, does the problem stays with a right side or follows the cable? If it's a cable, that's an easy replacement fix. Also, be careful with BA iems, dropping them can damage the driver.
Regarding the sound, typically BA drivers don't go through burn in, but the crossover component could. I have noticed sound changes even with multi-BA iems after the burn in, so give it a few days of play time Another thing, when you are comparing, are you using exactly the same eartips? Eartips can have a noticeable effect on the sound. The seal controls the low end impact and the top end sparkle. If you use silicone vs foam eartips, or smaller vs bigger size tips, they can affect low end.
