Iv'e seen people say that they distort a bit with heavy bass songs but in high volume but I don't know the source and if it's amped or unamped.
it depends on what you mean by "high volume" the XS is very efficient so yes it will distort if you push it above 85-90% on say an iphone/ipod touch (theres no reason to turn it that loud anyways, even if your say on the subway (50% is more than enough, i tend to say in the low to mid 40s even on the subway).
theres no reason for you push these past 60-70% unless your ears on on its way out.
if your amping it theres even less reason to turn it to the max (i used it sparingly with my fiio e6 which has a max volume of 62 or so clicks (compare to the iphone at 16 clicks, but the iphone puts out less juice, naturally)
however i'm curious what you mean by heavy bass songs, care to share a link? i'll test it out for you (on comp, on my ipod/iphone, fiio e6 amp) just lemme know
So how well do the XS' do with rock?
Does it sound bloated?
Sennheiser Momentum on Ears sounded too bloated for rock.
I can get the HD25 Aluminum for $119 now, or wait to get the XS.
if you see the alluminums for that price id snap it up. the xs is great really as a OVERALL package, if you want something that looks good on the head and around the neck ( i think so anyway) portable, comfortable, durable and "adjustable"-> bend the headband to the shape of your head/ alignment of your ears. (haven't heard of the hd25 but hearing the praise on the speed of the kick drums and other bass notes and that sparkly treble (might be a bit harsh for long term listening though)
i'll give the xs a try on some "rock" songs that i do have. lol but id imagine its a lot more manageable and less fatiguing with the xs
but be sure to post me a link on the songs you consider are "rock" its not really my genre per say
