- Aug 15, 2011
As far as I understand, DSD can be converted to legacy PCM (16/44.1, 24/96, ..., 24/352.8) or DoP (DSD over PCM).
And apparently, UAPP can play DoPFLAC and output a DoP stream.
About DoP:
"Since the Apple OS only allows a PCM path we have to find a way to put DSD audio data into PCM frames that then get sent via the native USB driver." [DoP open standard]
http://dsd-guide.com/dop-open-standard
About Herus & DSD:
"HERUS SPECIFICATIONS
Supported Formats PCM, DXD and DSD64/128 Uses DoP protocol 1.1 over USB for DSD"
http://resonessencelabs.com/herus/
About Onkyo HF Player:
http://www.digitalaudioreview.net/2013/10/onkyo-hf-player-resonessence-labs-herus-ios-dsd/
Cheers. With the Onkyo I already have that option enabled and with the Herus it plays DoP straight through - i.e. DSD Native. If I replace the Herus with the either Cypherlab DAC-Amp, it'll fall back to PCM even with DoP mode.
As for UAPP, I'm not familiar with DoPFLAC so I'll have to read up more about that next. I'd guess the trial version would work with DoPFLAC too, then I may be able to test UAPP on my Galaxy J -> Invicta which is the only way for me to confirm if it's actually decoding & playing DoPFLAC as DSD native.
Edit: In other words if Onkyo, which is capable of playing DSD Native on some DACs but falls back to PCM conversion the Cypherlabs DAC, I'm wondering if UAPP would be the same on Cypherlabs DAC too.
