- Aug 15, 2011
Wow, great pics from a great show. That Taivanese electrostatic headphones looked nice. Anyone can tell the name of the brand?
Found it, In2uit: http://www.in2uit.com/headphone/us/index.asp
Thanks for pics!
ELI5 for you: CD and DVD are made of plastic that said there is no magnetic flux on it around it etc. CD cannot be magnetized ... hope you see where this is going
Maybe it helps to discharge static that can build up on the disc. Might do a bit to protect components from stray electrons.
wipe it with anti-static wipe and you've got the same for $0,5
Through wipes will most certainly scratch the surface of a disc, and I'm guessing this device works without any physical contact.
Noble K10 Universal with Wagnus Sieve Sheep Cable
Ultrasone Edition 5 limited edition...and not
Bootsy1 said:/img/forum/go_quote.gif
Which amp is this with the Terra Player please?
It's a Vorzuge Duo and unfortunately there are huge sonic variances from Duo to Duo. This is my 3rd Duo and the best sounding one so far after trying out about 25 units(which all sounded different).
