Heyandress7
- Feb 7, 2015
How big is the oppo ha-2?
I was hoping someone else would mention this, as I am not as eloquent as you. the whole sounding better in a certain direction is total bunk. it's a conductive cable, and its not polarized.for the record, I have a degree in electronic engineering, this is bunk IMPO.
Have a pic? How do you stack them together?
What is the correct/best method to delete songs/albums?
I thought I could just plug it into USB and delete songs via the computer/mac finder etc. the same way you put music on (drag and drop). I deleted an album of mp3's and replaced it with the same songs but in FLAC, when I went back to X3 and updated media library both the mp3's and the FLAC's showed up?
However, they (mp3's) only showed up in category->artist not in folder view...
Same thing happened to me on my first gen X3, it must be a mac thing. For some odd reason it doesn't actually delete things when you delete them, it puts them into a hidden folder (mine was called .trashes). I don't know if you have a windows machine, but I plugged it into windows computer, showed hidden folders, and went in and deleted all of my music that was hiding in there. I'm sure there's a way to show hidden folders on mac, but I'm not entirely sure. In any case, that's likely what's happening: your music is quite literally hiding in a hidden folder.
With E12A...
I thought it lowered overall volume to prevent sound clipping. That is they way it's designed.
Personally I think the source should be neutral and you should color your sound through the headphones you use with, if needed, help from a bit EQing.
