Greetings all.
So a while back I made a thread and posted some comments regarding a new music player and headphones to replace my PsP 1000 + AFK K330 setup.
I can now proudly say I have made a major upgrade to a FiiO X3K (II) + Dunu DH-1000 IEMs.
I can say for sure that the 2 are a great match. No need to use the X3's software equalizer at all.
I will however mention that's its super important to chose the correct tips for the DH-1000's, thankfully they come with a vast variety of choices. I thought I would go for the foam tips but they didn't work out, but I did find a pair I liked and fit well, along with the red (largest) extension loop + rubber over ear clip. I know many people say these IEM's are heavy, and they are ...when ur holding them, but once u have them in ur ears u don't really notice, I don't at least.
The X3K has plenty of power to drive these IEM's, very loud at 120 volume + high gain with 0 distortion (Linkin Park 'In the End' FLAC). Ill likely only ever use 80-85 volume with low gain as I cant have them up to loud whilst im working in a busy vehicle plant....even with just 1 earphone in use (not allowed to have both earphones in).
The one and only thing I 'currently' can pick fault with is the screen, even at max brightness it just cant handle bright environments, but that's a TN panel for you I guess.
X3K £160, DH-1000 £130, Sandisk 128gb SD card £58 .... £348 well spent.
Now I just need to 'acquire' more lossless music.
