x RELIC x
If the X5 II FW is anything like the X5 Classic I'm afraid the answer would be no.
The Now Playing shortcut menu is far from great, because choosing options other than the first requires to use of the wheel which is annoying for accurate selection (it ignores clicks). Holding a button and clicking another is way way faster and easier to do.
Just purchased a Cayin C5 amp, to go with my X3ii. The amp comes with your standard 3.5-3.5mm cable. Would I gain anything by stepping up to the "nicer" FiiO L16 cable? I know this is kind of a subjective subject, but any insight would be appreciated.
To anyone with the Dignis case that hasn't figured this out yet. The easiest way to get the X3II out of the case is to use the plugged in USB cable to push it through the top of the case and remove it. I haven't figured out another way that is any better than this. Good luck!!
From my experience I believe cables make a difference as well as burn/run in time (some people don't of course).
I have had Fiio L2 (straight), L8 (angled) and L16 (straight) and I prefer the L2 + L8. Initially the L16 is impressive with more top end sparkle but closer comparisons after run in time shows the L2 + L8 have better/stronger bass and mids and equal top end detail compared to the L16. All are OCC copper.
IMO, it is important to mark the source end of the cable with marker or tape (or note direction of the writing on the cable) on the cable as the run in time/process makes the cable directional ( i.e. better sounding in one direction only)
However the L16 + L17 (angled) could be used to fine tune a darker sounding rig if required for example.
I am not a fan of silver plated analogue cables however solid silver is a different story but expensive and I also prefer silver plated digital/USB cables.
Of course we all have different preferences and hearing abilities but anyway experimenting for yourself may make the difference you are looking for!
Thank you for the informative answer. I guess it all comes down to what "I" hear. So, I'm going to have to do some experimenting with different interconnects. Appreciated.
Take a look at this one: http://ghentaudio.com/part/d01.html (Canare L-2B2AT) 1ft = $10
or this one: http://ghentaudio.com/part/d11.html (Canare L-4E6S) - 1ft = $12
Extremely high quality and both are very affordable. The only downside is the wait on the shipping. High quality cable gains are always up for debate, but these are worth the small cost IMO (if you are looking at aftermarket cables that is).
I apologize if many think this is a silly question but I am a little new to this. Will the above cables produce better quality sound than this cable:
http://www.ebay.com/itm/111184516268?_trksid=p2060353.m1438.l2649&var=410221734350&ssPageName=STRK%3AMEBIDX%3AIT
I have been looking to get decent cables but want the biggest bang for my buck. Thanks!
Try this: Use the Now Playing menu to get to the option that's one before last (the one before Delete Song), think hold long it took you. Now try holding Play and Clicking Back. Now tell me which option is faster and easier.
